2000 Venture remote start
Google
Web AF
7t3vette
09-15-2003, 08:55 PM
i'm trying to hook up to the tach wire at pcm. supposedly it is a white wire at pcm (only problem is there are 4 white wires) Does anybody know which pin number it is, because the Haynes manual does not give pin numbers.
Thanks, larry
weezey2u
09-24-2003, 02:26 PM
Use a ohm meter to test the wires this will tell you witch one to use
jimbo69ny
09-26-2003, 11:20 AM
an ohm meter will do nothing. you need to use a meter that will test for ac voltage. put the negative wire of the meter to ground and the positve to the white wire you want to test. with the car running it should have low voltage around 1 or 2 volts. when you push the gas and rev the engine the voltage should increase. ususaly on most cars it will only go up to around 6 volts.
hope this helps
jim
ponchonutty
09-27-2003, 03:12 PM
Thanks, larry
Actually, you are wrong. It is the purple/white wire. This can be found at the ignition coil pack or at the PCM. If you want to get it at the PCM it is located in the aircleaner assembly on the passenger side. It is in the blue plug at position 8.
If you have a simple testlight, you could probe it and if the car stalls, that's the one. I caution you to do this way though.
weezey2u
10-06-2003, 10:08 PM
hope this helps
jim
How many ohm meters do you know of that dont test ac current?
jimbo69ny
10-07-2003, 10:24 AM
Well to get techinical, a Ohm meter is just an Ohm meter. A Volt/Ohm meter does all voltage, current, and ohms. Or you can get a DMM (Digital Multi Meter) which also does all voltage, current, and ohms. The DMM just in digital rather than analog.
weezey2u
10-08-2003, 01:21 AM
Man i was joking you dont have to be so technical about it i guess i should of said use a multi meter i just get use to calling it a ohm meter next time i will be more accurate with my advice thanks for pointing it out i dont want to confuse anyone
ponchonutty
10-08-2003, 10:27 AM
:banghead:
mbsaudio
12-02-2003, 08:30 PM
sorry to join late.easiest tach--large split loom over engine. only one white wire in it. use it all the time
Google
Web AF
