change oil soon
Google
Web AF
mr. krinkle
09-11-2003, 11:47 PM
how do i reset the change oil soon light? i have done it before but i forgot the sequence. i was also wondering if there is any way to turn off the daytime running lights.
thanks,
mr. krinkle
mr. krinkle
09-15-2003, 06:19 PM
i guess i forgot to mention that the car in question is a 97 grand prix gt. oops.
grandprixguy
09-18-2003, 02:00 AM
i just read about this somewhere... pump the gas pedal like 3 times in 10 seconds i think :eek7:
Cokeroker
09-18-2003, 01:55 PM
turn the key to the "on" position, but do not start the car. Then pump the gas pedal 3 times in a row.. that should reset it
mr. krinkle
09-25-2003, 08:43 PM
:confused: I tried the pump the gas thing and here's what happened: 3 times and the side marker lamps went off, 4 times turned them back on. But now when i use my remote start (viper) the lights dont flash like they used to. And when i set my alarm, the marker lights flash. before i tried this stuff, the marker and head lights flashed when i set the alarm. Wierd.
Anyone know where i can find a book that would tell me about resetting warning lamps, etc.?
thanks again
GMMerlin
09-25-2003, 09:47 PM
Look in your owners manual..the reset procedure is in there
The Burning Rom
09-27-2003, 06:35 PM
You can turn the DRLs off one of two ways. YOu can either pull the DRL fuse, or you can install a bypass switch from www.zzperformance.com
Gooose8
09-27-2003, 06:57 PM
After changing the engine oil, With the ignition in RUN but the engine off, Fully push and release the accelerator pedal slowly three times within five seconds. If the CHG OIL SOON light is flashes, the system is resetting. Turn the key to off and then start the vehicle. if it don't work repeat the procedure.
Good Luck
Google
Web AF
