engine light on!!! NEED HELPjetta3gl 09-11-2003, 09:54 PM I just removed my air box and put a k&n filter on to the end of the air flow sensor. The car ran fine with much more power for 2 days then the engine light came on and car lost power. Does anyone know if the new filter is the problem or if it would be something else. ImportFool 09-18-2003, 11:49 PM I just removed my air box and put a k&n filter on to the end of the air flow sensor. The car ran fine with much more power for 2 days then the engine light came on and car lost power. Does anyone know if the new filter is the problem or if it would be something else. alright man, there is a very simple way to fix this problem..how to get ur engine light to go off...ok step 1. remove ur gauges from the housing 2. remove the gauge covering sheet 3. take a permenant marker 4. color the check injen light icon on the sheet in wolla!!!! put it back together and ur check engine light will out, or will it??? :naughty: j/p jetta3gl 09-19-2003, 04:21 PM Hey importfool did you read the part about the loss in power. I can't just negger rig it you FOOL. I need to figure out whats wrong with the car so the light goes off and I get back the power. ImportFool 09-19-2003, 06:54 PM Hey importfool did you read the part about the loss in power. I can't just negger rig it you FOOL. I need to figure out whats wrong with the car so the light goes off and I get back the power. calm down dude....i was just messin..aint u got n e type of sense of humor?? :shakehead i have the same thing wrong wit my jetta...the motor light comes on occasions...and i lose alot of power...i would say u should get a new oxygen sensor, but since its damaged it throws off the fuel and gas ratio, and thats why i think i lose power...but also when the light comes on my car starts makin a horrible ticking noise...im gonna get it checked out soon..so ill let u know when i get mine checked out, and hopefully it might help u... ImportFool 09-19-2003, 06:56 PM i would say u damaged ur oxygen sensor....thats what i think is wrong wit my car... jettaboy 11-04-2003, 11:57 PM my jettas engine light came on, dealer said mass air flow sensor, its been recalled, at least for my 2000 gl, but it has not come on since. ImportFool 11-07-2003, 10:58 PM ive heard that it may be the maf also...but im not sure...im waitin for the car to die so i can disect it, since everything is failing :biggrin: HeirMuench 11-09-2003, 11:31 AM I do know of many problems with MAF's. But there are a few things you might want to make sure of. Make sure that the new filter is somehow anchored so it is is not just flopping around. Also, if you have a secondary air system, (a plastic hose that also goes to the airbox), make sure it also has a filter on it. Unfiltered air through the secondary air system will void warranties. blm0332 04-09-2004, 11:04 PM I also have a 99 jetta III gl and had the same exact problem. i took it to Bert Smith VW and they dagnosed the problem as the some kind of brain sensor. I think it is called the MAF. It was covered by VW and I only paid for the diagnostic testing. The car has run great since then. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
