Taillight bulb replacement
Google
Web AF
tmf2
09-05-2003, 05:44 PM
Whats the secret ? I can't seem to get to the bulb. Is this a sealed unit
if so how to you get into it ?
Thanks Dennis
SapphicCat
09-16-2003, 04:49 AM
What year rodeo, and which rear light?
ldg427
10-07-2003, 10:41 AM
Thanks Dennis
I am having the same problem with my 2000 Rodeo. I'm trying to get to the taillight bulb on the driver side and have undone the 2 screws on the side as well as the one underneath but it still doesn't seem to want to come out. Were you able to figure out?
Thanks
ldg427
10-07-2003, 03:31 PM
Thanks
Nevermind. If I had taken just a little longer the first time I would have figured it out. I've replaced the bulb.
cnn
11-03-2004, 01:10 PM
I can't figure how to get the tail light out to replace the brake bulb. How do you get the bottom screws out w/out taking off the bumper? It's a 1999 Rodeo. I've checked all the threads in this forum. Thanks.
amigo-2k
11-03-2004, 04:46 PM
http://www.geocities.com/endre_rl/isuzufaq.htm#faq46
cnn
11-03-2004, 06:49 PM
Thanks, but my problem is I can't figure out how to take out the bottom screw. I'm mechanically challenged I guess.
2eyefishclaw
11-03-2004, 09:38 PM
stand behind the vehicle grab hold of the lamp assy. and pull hard straight back
cnn
11-03-2004, 10:56 PM
I still can't figure out how to get to the bottom screw (between the bumper and the bottom of the assembly). There's hardly room for the thickness of a finger let aone a screwdriver...and that's with the screw all the way in. What am I doing wring?
amigo-2k
11-03-2004, 11:38 PM
You need a long narrow screw driver to get it out.
cnn
11-05-2004, 01:35 PM
Thanks for all the help. The problem was I was looking at the wrong bottom screw. The only ones I could see attached a piece of trim to the bottom of the assymbly. I couldn't see the one that attached the assymbly to the body!
2000RodeoLS
12-02-2004, 12:05 PM
I am sorry, can someone please tell me where the screw that attaches the assembly to the body located? is it located behind the small piece of trim at the bottom of the light assembly? I am having a hard time locating the third screw? Thank you in advance!! :)
Dober89
12-02-2004, 05:45 PM
Theres the 2 on the side and ones on the bottom towards the inside of the truck. Its sorta hard to see and you need to use a long screwdriver to get it out. Its basically right above the bumper.
cnn
12-02-2004, 11:22 PM
it's so simple but so hard...just get a flashlight and look at the bottom of the glass assembly...it's a dark phillip's head at the bottom rear of the assembly.
2000RodeoLS
12-14-2004, 10:15 PM
THANK YOU!! That was driving me crazy! IT is not an easy feat, either! Thanks again very much! :)
mospeed1
12-15-2004, 07:29 PM
the hard part is getting that bottom screw back in!!!!!
delsua1
10-29-2006, 09:32 AM
I still can't figure out how to get to the bottom screw (between the bumper and the bottom of the assembly). There's hardly room for the thickness of a finger let aone a screwdriver...and that's with the screw all the way in. What am I doing wring? Please I need you to help me figure out how to replace the bulb.
delsua1
10-29-2006, 09:40 AM
Please I need help to replace the brake bulb I can't take off the exterior cap where the inside bulb goes I unscrewed both screws but it won't come off how do I take it off.
amigo-2k
10-29-2006, 10:00 AM
there are 3 screws.
You need a long phillips screw drive to get to the one by the bumper at the bottom.
delsua1
11-01-2006, 06:06 PM
I still can't figure out how to get to the bottom screw (between the bumper and the bottom of the assembly). There's hardly room for the thickness of a finger let aone a screwdriver...and that's with the screw all the way in. What am I doing wring?i got the two side screws but can't find the third can you please help me.
amigo-2k
11-01-2006, 08:11 PM
It is on the bottom of the light, get a flash light and look where the bumper mets the light.
Google
Web AF
