Spark plugs
Google
Web AF
jennykert
09-03-2003, 05:14 PM
Can anyone let me know the correct spark plugs to put into an 2000 Isuzu Rodeo 4WD?
Our Rodeo was having some trouble, so we replaced the spark plugs with Bosch platinum plugs. After 4 trips to the dealer, in the last 2 weeks, paying thru the nose each time, they are now telling us that the problem is the spark plugs. They insist we must use Champion plugs. My husband feels Champion plugs are inferior and thought he was doing a good thing by putting in better plugs.
Because our the service dept with our dealer has not dealt fairly with us in the past, I called another dealer, who told us to use Denso plugs.
Then I called Isuzu directly and they told us to use NGK (they said Denso was ok too) But said that the only plugs they do NOT recommend is Champion--funny but that was what was factory installed.
We are getting a P1340 error - ignition circuit sensor error-Check engine light is always on- misfires when started in morning. After replacing the fuel regulator, they now say it is the spark plugs.
Of course warranty ran out 1 month ago and we only have 26,600 miles on the car.
Thanks
Jenny
rodeo02
09-03-2003, 10:38 PM
Jenny- The 3.2 & 3.5 engines are super sensitive to spark plug brand because of the engine electronics. Especially the 2000+ models. You should stick with the brand that came with it from the factory, but denso's or NGK's will be your best bet. Champions have been known to cause issues on 2000 & up models. Many 1998-1999 came w/ champion spark plugs, but all of the 2000+ I've seen have either denso or NGK. They are pricey plugs, but they will solve your problem. These plugs will EASILY last 60Kmi+, but you'll want to pull them out, re-lube & re-install them every 30Kmi to prevent the plugs from seizing into the aluminum cylinder heads. G/luck!
Joel
huios
01-05-2004, 11:29 PM
I bought a 95 rodeo today v6,and its missing mostly in drive and especially between 45 and 50 mph.It does miss a bit in P. I came home and I opened the hood and being that it was dark I saw arching one the plug wires on the right side guess there split or something. Also When I accelerate I here what sounds like a cricket under the hood.CAN SOMEEONE TELL ME WHAT THIS IS??
Google
Web AF
