Audi CoupeBrixen 09-02-2003, 02:57 PM I'm a newbee, and this is one of my first chops. Pls give me your evaluation of the chop. Import_Tuner 09-02-2003, 03:14 PM Hey Thats great if your a newbie! But whats up with the windows... :eek7: Also i can see where you tried to cover up the bit of the roof and rear you cut out to make it into a coupe. Try rotating the bits you cut out to try to cover it up to blend in more with the lines of the door etc. (garage door area just above the roof) CivicLeader 09-02-2003, 03:57 PM Good job for just starting out... I still haven't tried mod's such as this...still messing around w/color's and what not... Keep it up! CL crxlvr 09-02-2003, 04:02 PM not bad, but listen to import about the mis-angled lines of the garage door and stuff. keep up the good work. CivicLeader 09-02-2003, 04:06 PM Good job for just starting out... I still haven't tried mod's such as this...still messing around w/color's and what not... Keep it up! CL LadyLuke 09-02-2003, 04:33 PM Aweesome work for a noob...Try blending in the roof line a little...i can still see where you chopped it. Maybe i will give you a link for my first hatchback...You can laugh at it then. spididdy 09-02-2003, 07:27 PM :iceslolan :iceslolan :iceslolan :iceslolan :iceslolan :iceslolan :iceslolan :iceslolan :iceslolan Brixen 09-03-2003, 03:35 AM Thanks for your advice and comments. Somehow I knew I should have spend some time on the windows, but I was too lazy. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
