shaving door handles
Google
Web AF
Autoflow
09-02-2003, 11:48 AM
ok i want i shave the handles and the key slots what do i use to fill in the space and after i fill it in can i just prime it and sand?
perna00
09-03-2003, 01:14 AM
i've personally used jb weld on the door locks of a different car i had. it seems to be one of the strongest and doesn't need any reenforcement screens behind it or multiple layers like bondo (although it does work also). i just sanded it and primed it and it never gave me a problem
fmwiebe
10-09-2003, 07:03 AM
Weld metal in solid and fill with body fill.
Did that to mine and had no problems.
krebs128
10-09-2003, 09:41 AM
try to use as little bondo as possible cause it could crack and that'd ruin it. if u get a good weilder, he shouldn't have to use any bondo at all.
sweetwhiteCAV
10-09-2003, 01:07 PM
im planing on doin this in the spring, i was thinkin about tackin (welding) a small patch behind the keyhole, and any other holes and filling the outside with bondo
fmwiebe
10-09-2003, 11:26 PM
If you tack weld it the welds are very likely to rust. Weld them in solid and less chance of rust. Be careful not to overheat the meatal and warp it. Really pisses off the body man
oheocaracer
12-22-2003, 01:10 PM
what do u mean by weld the metal in solid
do u make it flush with the door or slightly behind leaving space for bondo on top
Google
Web AF
