"Check engine" light; sulphur smell - related?
Google
Web AF
berdov
08-28-2003, 08:16 AM
I have a 2002 Camry V6. Early on I smelled sulphur. The dealer tried to convince me that the smell comes because of short drive distances and is absent on highways. I did not beleive the explanation because I smelled sulphur on highways as well and because it did not make sence from the design point of view; but I had no desire to argue and went back to my busy life.
About ten days ago, the "Check engine" light came on. A mechanic told me it MAY be related to the exhaust system malfunction. When I suggested this to the service rep at the dealership this morning, she told me that her 2003 Toyota stinks suplphur all the time, including the highways.
I do not think that anyone is in business of manufacturing stinky cars. Will appreciate any technical or semi-technical explanation of the a) smell and b) the reason(s) for the "Check engine" light.
Thank you.
Boris F.
TorinoGT69
08-29-2003, 07:27 PM
The sulfur smell usually comes from the catalytic converter. It may indicate a failure but I have heard that the gas mixtures in some parts of the country can cause the smell as well. I suggest you run a code scan and find out why the check engine light is coming on.
Roswell
11-23-2004, 12:35 PM
This is almost completely theortical but check the injectors as well. I've heard of exhaust problems stemming from leaky injectors. the rich fuel mixture causes a chemical reaction with the catylitic converter and can cause funny smells when it melts the medium in the converter.
Could be a place to start.
csaxon
11-23-2004, 04:43 PM
It could be just the seasonally winterized gas mixture thats starting to be distributed but there is a Toyota technical support bulletin.
TSB EG011-04 May 13, 2004 Title "Excessive Carbon Dioxide Odor". '02-'04 Camry. Your dealer should look it up and check your VIN number to determine if it's one of those needing a new catalytic converter. The warranty code for the free replacement is OP CODE 170171 "R&R Catalytic Converter Assembly. Time 0.6 OFP 17410-0A340 The warranty is for 96 months or 80,000 miles. If the dealer claims ignorance then contact Toyota.
Google
Web AF
