removing door panel *help asap*
Google
Web AF
dirtydx
08-23-2003, 12:53 PM
k i think i have all the screws out.. im just stumped on getting the window crank handle off... :feedback:
4GZChatch
08-23-2003, 01:29 PM
Just turn the handle so that the knob is pointing up, then look down the back of it. You should see a little wire loop. Just grab on to that with your needle nose pliers and tug up on it. It should just pull off, since it's a spring clip. Then put it back on the handle so you don't lose it. Then, to put the handle back on, leave the clip on the handle (make sure it's in the right position so you can get it off again if you need to) and just push the handle on the gear. If you have any other questions, just email me at josh@zerodragtuning.com. Good luck! :smokin:
dirtydx
08-23-2003, 02:54 PM
thanks a lot :smile:
Google
Web AF
