Fan switch recall?2001-325i 11-30-2001, 10:50 AM Does anyone know anything about a recall for 3 series cars built in the first part of 2001? Thanks! ambasah 11-30-2001, 04:35 PM I believe it only affected cars with stick. Mine is finally running ok. bmwworld 12-02-2001, 02:07 PM Alldata publishes Automotive Recalls and Technical Service Bulletins. Their link for 2001 BMW's is: http://www.alldata.com/TSB/0106_mo.html sq_man 12-05-2001, 02:08 PM Which fan? Heat and A/C? If so, I had a problem with my A/C fan randomly changing speeds and they fixed it at the dealer. I have a 2001 325i. bedheadfred 12-06-2001, 12:34 AM I'm not sure if there is an official recall on the fan, but I have had problems with my a/c, apparently it was a blower that wasn't working properly. I have a 2000 323ci and have also had the following problems, so beware: 1. Wrong setbelt configuration installed on drivers side 2. Sunroof broke (2x) 3. A/C broke 4. Coolant thermostat replaced 5. Plastic screw that holds jack in place broke (took me 2 hours to unscrew so I could replace a flat) 6. 4 light bulbs out in 6 months (2 left side turn signals, 1 left head light, 1 right head light All these problems occured in less than 20,000 miles. Good Luck to you. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
