Keyless entry
Google
Web AF
Icelso
08-17-2003, 09:22 PM
I have tried everything to try and program the key transmitter on My 1995 Honda Odyssey EX. Please Help Me!
lorunner
08-21-2003, 08:18 PM
Try turning the key on and press the lock or lock button (really doesn't matter) once and turn the key off. do this three more times but the last time leave the key on, the locks while cycle then hit the lock button on the other remotes and turn the key off.
Solderwick
01-19-2004, 11:23 PM
I have a '98 EX. These instructions as follows worked beautifully for me.
1. Open the driver's door and leave it open.
2. Hold the lock/unlock lever (not the plunger on the top of the door- the silver lever above the power window controls) in the "up" or "unlock" position and keep holding it up with your left hand. Don't let go until step 5 is completed.
3. With your right hand, quickly insert and remove the key from the ignition switch five times within 10 seconds, then insert the key the sixth time and leave it in the ignition switch. This means only inserting the key, NOT turning it to any position such as I, II, or III. All the doors will lock and unlock to indicate that the control unit is in the program mode.
4. Press either button on the replacement transmitter. All the doors except the driver's door will lock and unlock to indicate that the control unit has accepted the transmitter into its memory. If either transmitter button is pressed again, all the doors will lock and unlock.
5. To program a second transmitter, press either button on that transmitter. The doors should lock and unlock as described in step 4. This also means that ALL transmitters, even the original one if you are adding another, must be programmed in this step. It seems that the systems "forgets" any previous programs whenever you enter the above mode.
6. Release the driver's master door lock switch.
7. To exit the program mode, close the driver's door or remove the key from the ignition switch.
I hope that helps anyone else who needs this info.
-Ken-
Xanadu_here
02-04-2006, 06:15 PM
How about a 2000 Odyssey? I did it once and now I lost my instructions!
Onblsht
02-06-2006, 07:49 AM
99-04 programming:
do steps 1 - 12 on the same remote AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH BE HAVE TO REPROGRAM. the following steps 1-12 are done on a single remote step 13 is done on all remotes to be programmed upto 3 can be programmed
1) get into the car shut the doors and make sure they are unlocked
2) turn on the ignition (do not turn on the car just the ignition)
3) press the lock button on remote (turn to off )
4) turn key to the accessory ON position (your radio works in this mode)
5) turn on the ignition (do not turn on the car just the ignition)
6) press the lock button on remote (turn to off )
7) turn key to the accessory ON position (your radio works in this mode)
8) turn on the ignition (do not turn on the car just the ignition)
9) press the lock button on remote (turn to off )
10) turn key to the accessory ON position (your radio works in this mode)
11) turn on the ignition (do not turn on the car just the ignition)
12) press the lock button on the remote
the locks should chirp to indicate that programming mode was entered successfully
13) press the LOCK button on remote the doors should chirp again to confirm programming THIS STEP NEEDS TO BE DONE FOR EACH REMOTE
14) turn of the car fully and try locking/unlocking with remote
Google
Web AF
