2000 Impala - Airbag dummy lightleerider 08-14-2003, 02:53 PM has anyone else had any problems with the dummy light for the airbag going on and then off... I have seen other write ups on this and it seems to be an error in the cpu and not teh airbag itself. Can anyone confirm or denie this report? Thanks, Lee GMMerlin 08-15-2003, 04:08 PM If the SIR light comes on it stores a diagnostic trouble code to aid in diagnostics. The problem could be anywhere in the SIR circuitry or hardware. I would recomend you take it to a trustworthy technician and have it looked at. victimizati0n 08-19-2003, 07:16 PM Right when you start the car it is suppost to come on Swiss 08-30-2003, 04:43 AM My does the same thing- it has to do with a connection issue. When I hit a bump it goes on and off. Just bought the factory manuals and will try to trace.I let you know if I find it...please do the same. wat71 10-29-2003, 02:44 PM I have the smae probelm It seems that after i went thru a big puddle or was that a river Yes In NJ i seemed to get the indicator light I am sure it is in the sensor conection a hard right turn turnns off the light and a bump turn it on has any one fixed i assume you disconect battery and fuse and i will be abel to spray with a wd-40 type oil water siplacemnt sytem any responce woudl be nice Alex Swampbaby 01-18-2004, 10:49 PM My does the same thing- it has to do with a connection issue. When I hit a bump it goes on and off. Just bought the factory manuals and will try to trace.I let you know if I find it...please do the same. We are having a very similar problem. Did you ever find out the fix? balldlox 02-22-2004, 09:22 PM My 2000 LS also has this problem. A trip to the dealer ended with a brake fluid top up. ?????? I was told that the air bag circut is linked with ABS circutry and low fluid level will trigger light. It did fix the problem for a week but its back now, on and off as I remember. And yes fluid level is still up. Stephen B 02-23-2004, 12:35 AM I have the smae probelm It seems that after i went thru a big puddle or was that a river Yes In NJ i seemed to get the indicator light I am sure it is in the sensor conection a hard right turn turnns off the light and a bump turn it on has any one fixed i assume you disconect battery and fuse and i will be abel to spray with a wd-40 type oil water siplacemnt sytem any responce woudl be nice Alex Alex, don't spray anything on the connectors! The type of connectors used on todays cars are referred to as "weatherpack" connectors and if they become contaminated with any substance it means hard times ahead. These connectors are engineered to take as much as 45PSI pressure before allowing external leakage. If anything you may want to have the system scanned. It will cost a few dollars but considering the number of items involved, it's worth it simply from a time/cost benefit. sweet thang 03-01-2004, 08:14 PM I had this problem too but they told me that it would cost $400 to fix and I was like whatever and I blew it off but I will try and find my sheet that says what the problem was. I think they were bullshiting me cause I'm a girl, blonde and they thought I was stupid autoforum 03-16-2004, 09:06 PM Second time this happened to me. The first time the dealer said it was a connection and fixed it for about two months. Now it's happening again. I'll just have them fix it the next time I have to take it in for something else, notably the recall for the radiator I just received. lkh1026 04-13-2004, 01:17 PM We had this same problem after having to slam on brakes to avoid an accident. After taking it to the dealer (this time they fixed something right on the first try). Reading the repair paperwork - word for word it says: Problem: Air bag light stays on Comment: SIR SIR REPAIR 294 CC cleared connectors and cleaned RF seat code. The cost of repair was 88.04 Hope this helps. Linda vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
