Diagnostic helpGreenwithEnvy 08-12-2003, 04:39 PM I've got a 96 Z71 pickup with the 5.7 and 4X4. The I'm trying to pull codes from the ECM using the jumper wire to short the A port to the B port on the ALCL plug. I have located a plug under the drivers side dash. Is this my ALCL? Also, how are the plugs pinned out? I have the 2 plugs to the farthest right , top and bottom jumped together and I can not get my check engine light to blink. I know the plug is ported A thru M and skipping I. Which two ports are A and B? 4freddie 09-01-2004, 10:49 PM 95 and newer require a code reader. go to autozone for a free scan and good starting point DaMoNe6969 09-03-2004, 12:07 AM You've got the OBD2.. a little more advanced than the old "jumper wire" diagnostics.. You can buy an obd2 scanner, here they are about $180cdn.. Or You can take it to a shop like 4freddie mentioned, but here they charge you to scan it SpitAndDirt 09-04-2004, 02:13 AM http://obddiagnostics.com for a free software download that will allow you to use a laptop to interface with your vehicle. Only downside, you do need to buy an interface, unless you are capable of building one. -Chris gschretter 09-06-2004, 01:34 AM I am looking to buy a K3500. I have the code reader but where is the port in order to pull the codes? Thanks SpitAndDirt 09-06-2004, 02:59 PM Under the drivers side dash. Usually located nearly underneath the column. 16 pin connector. You really can't miss it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
