Keyless entry Questionthewolf73 08-12-2003, 12:08 PM I have just purchased a 2000 trailblazer and it only has one remote. I have 2 more remotes that are numbered 1 and 2 that I would like to program. 1st question is how do I program these and will they work being they were for a gm car? 2nd question is I would like to have the door locks engage when the car starts moving and unlock when it is put in park, I am sure this can be done but I don't know how. Please help Flatrater 08-12-2003, 07:44 PM Here is how to program remotes the part numbers have to match the one that works otherwise they won't program!! With the driver door closed, hold down the power unlock button on the door panel. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode: Locking the doors Unlocking the doors Important All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated. Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner: Locking the doors. Unlocking the doors. Repeat step 7 for each additional transmitter. Turn the ignition switch to the ON position in order to exit the transmitter programming mode. In order to reprogram the remote control door lock transmitter with a scan tool, refer to Scan Tool instructions. Flatrater 08-12-2003, 07:46 PM As for your second question if it is possible to change your options you would have to look in your owners manual!! There are some very good things in the owners manuals, things you can change or do so please refer to it!! Not all GM trucks have to option of changing the factory settings!! thewolf73 08-14-2003, 01:25 PM Thanks for the response. I am curious though about the part numbers on the remotes. Which ones are they? The one that came with the Blazer has 3 numbers on it. GM/UTA 15732805 FCC ID : KOBUT1BT CANADA : 1983 101 393 New remotes are as follows- #1 Labled GM/LEAR 25695954 FCC ID: KOBLEAR1XT CANADA : 3521 102 1718 #2 Labled GM/UTA 25665575 FCC ID : KOBUT1BT CANADA : 1983 101 393 As for my second question, I do not see anything at all in my owners manual. I have however talked to the service dept at our local chevy dealer and they said that it should be able to be done. I guess I may have to bite the bullet and pay them their outrageous shop charges. Thanks again skt7460 06-29-2007, 06:34 AM Thanks also for the info. I reprogrammed both of my Trailblazers (2003 & 2005) using these instructions. Another question.. How can I reprogram the action taken by the power locks after I start my TB? By default the doors lock when the gear shift is moved from park to drive, and unlocked when shifted into park. During my attempts to reprogram the clickers I changed this action and now the doors lock 15 seconds after I start the car. Unfortuantely I started the car to cool it and let it run. When I came out 5 minutes later my keys were safely locked IN THE RUNNING CAR...duh! Luckily I had a spare key. How can I change this "auto action" for the power locks? Thanks! skt7460 Onblsht 06-30-2007, 01:15 AM Those are definately the wrong remotes for the Trailblazer models. They should be FCC: MYT3X6898B and part numbers 15008008 and 15008009. A "Regular" Blazer model (not Trailblazer) in 2000 would use FCC: KOBUT1BT and Part # 15732805. skt7460 06-30-2007, 10:08 PM I am not the same person who posted the first reprogramming question. Sorry for the confusion. I inadvertently re-programmed my automatic locks for 15 seconds after ignition vs. when shifting into drive (or out of park). I need to know how I can re-reprogram the auto locks. Thanks. jodyaskey 10-01-2007, 05:10 PM i'm clueless when it comes to anything automotive. i own a 2005 Trailblazer. all of a sudden last night the keyless entry stopped working. i thought it was the battery. i have since replaced the battery and still no luck. any suggestions? i was told it could be a fuse, but i dont know which fuse, and the manuel is not specific enough for me. can anyone tell me what i can do other then take it to the dealership and pay for something that should be so simple? envoyxuv 10-06-2007, 11:04 PM Thanks for the response. I am curious though about the part numbers on the remotes. Which ones are they? The one that came with the Blazer has 3 numbers on it. GM/UTA 15732805 FCC ID : KOBUT1BT CANADA : 1983 101 393 New remotes are as follows- #1 Labled GM/LEAR 25695954 FCC ID: KOBLEAR1XT CANADA : 3521 102 1718 #2 Labled GM/UTA 25665575 FCC ID : KOBUT1BT CANADA : 1983 101 393 As for my second question, I do not see anything at all in my owners manual. I have however talked to the service dept at our local chevy dealer and they said that it should be able to be done. I guess I may have to bite the bullet and pay them their outrageous shop charges. Thanks again Haha! i recognize that first part number- 25695954- that would fit a 2002+ pontiac grand am! emt1134 10-08-2007, 12:19 AM i'm clueless when it comes to anything automotive. i own a 2005 Trailblazer. all of a sudden last night the keyless entry stopped working. i thought it was the battery. i have since replaced the battery and still no luck. any suggestions? i was told it could be a fuse, but i dont know which fuse, and the manuel is not specific enough for me. can anyone tell me what i can do other then take it to the dealership and pay for something that should be so simple? It is possible that the key fob has to be resynchronized with the vehicle. Freak things like this just happen sometimes. Onblsht 10-08-2007, 12:55 AM Hold LOCK and UNLOCK on the remote (after you replace the battery) for 7 seconds near the vehicle to resynch it. bobbygee 10-31-2007, 02:53 AM I have a 2002 trailblazer. One of the keyfobs got into the hands of my ex. Can I reprogram the keyfob I have been using all along .... so her keyfob will not work on my TB? Thanks Onblsht 10-31-2007, 03:03 AM Once you enter programming mode your receiver's memory is erased and blank. Only the remotes you program at this point will work. This will make her remote useless...but if she has a key, she can still get in. bobbygee 10-31-2007, 06:32 PM OK, thanks, I don't know how to reprogram the existing keyfob that I have. I bought my TB new in 2002, so I know I have the correct FOB,any thoughts as to how to reprogram the fob? If she has a key ( I am not certain) is that a key with a chip? It opens the door and tailgate, don't want the ex in the car under any circumstances. TIA, Bobby A1QTEE74 01-26-2009, 11:19 AM I own a 2003 Chevy Trail Blazer. LTZ Yesterday the keyless entry romote stopped working, so i replaced the battery, but continued to not work. Can Someone please help me. Not sure why this is happening. thank you. MT-2500 01-27-2009, 10:09 AM Welcome to AF. This post is over 2 years old. Always check date on a post. If it is old. Start you own New thread /post and someone will help you. MT-2500 01-27-2009, 10:10 AM Welcome to AF. This post is over 2 years old. Always check date on a post. If it is old. Start you own New thread /post and someone will help you. C lightning 09-19-2009, 10:29 PM I have a 03 jimmy and my keyless entry stopped working so i replaced the battery and followed the directions on the fob and still its not working what should i do. Onblsht 09-19-2009, 10:55 PM ****Make sure you are not pressing the brake pedal at all during the procedure as it will interfere with programming mode. * *** Also, some customers report success programming with the driver's door open - where others report success with all doors closed. C lightning 09-20-2009, 02:36 AM Thanks for advice and i tried it but still wont work can anybody offer some advice as to what i should do without replacing the fob. how do i know if my fob is toast vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
