J 36850 Assembly Fluid - what is?mjrodney 08-10-2003, 03:09 PM Can anyone identify the generic aftermarket name for GM's J 36850 assembly fluid? What exactly is it? pcv 08-11-2003, 08:21 AM GM cannot identify that particular part. What do you need it for? mjrodney 08-11-2003, 12:36 PM The website Alldata.com claims that it is applied to the Automatic Transmission oil pan gasket during reassembly (Silverado). Anti-seize? GMMerlin 08-11-2003, 01:53 PM Just clean the gasket with solvent,dry and reinstall....torque to 10ft/lbs. If the pan is equipped with a drain plug, put a little Loc-tite on the trheads. mjrodney 08-11-2003, 02:23 PM What type of Loctite do you recommend? GMMerlin 08-11-2003, 03:02 PM Medium strength...the blue stuff. mjrodney 08-11-2003, 03:44 PM Thanks very much for the help.:bigthumb: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
