91 tracker has miss when acclerating
Google
Web AF
versatech
08-09-2003, 02:14 PM
Have a 1991 Geo Tracker who surges after engine reaches operating temperature. I had no problem before a hose going to the tbi broke and leaked antifreeze. Repaced the 10 inch long hose, distributor cap rotor wires and plugs....Same old same old Haven't used the car in a year so sad. Also the distributor cap was arching at the base a little Couldn't get the correct insulator from chevrolet, so I seal it with black silicone....Still misses, but only under acceleration, not idling.....Thanks folks
:confused: :spit: :icesangel
dyanne
versatech
12-06-2003, 10:22 AM
SUCESS :rofl:
I finally got my sweet Tracker healthy. It was the the Throttle position sensor. The pinouts on the haynes manual were labeled wrong. Found out when I checked resistance on high throttle. Couldn't adjust within range on ohms to 2k-6.5k at full throttle at idle the spec was .3 to 2k ohm Hope this helps any one with engine miss.
brit_gal
07-10-2008, 03:17 PM
Hey, I have a 91 tracker that misses too. I removed distributor cap wires and plugs and replaced according to the manual but its not working at all now. Where is the manual wrong? help help help!
Google
Web AF
