24 psi boost in WRX???darkaccord 08-03-2003, 10:27 PM Can an '03 WRX withstand 24 psi boost (with an aftermarket turbo) without exploding? FuJi K 08-04-2003, 12:20 AM Yes it can with good tuning. Running on 24psi for a long period, maybe it can but....24 is really pushing it though unless you have good tuning. I'd say don't go any higher than 25psi because the internals might go out. ssjwizard 08-04-2003, 08:04 PM thats a realy high psi there. it can probably take it but damn thats alot of turbo dropmech 08-09-2003, 10:00 AM IMHO, I wouldn't go more than 19psi if you plan on sticking with the stock internals and will be driving your car as a daily driver. cdeater 08-16-2003, 01:23 PM The WRX can probably hold 24 PSI if properly tuned. But I don't believe that the Rally Team runs that much boost pressure in there cars. Why would you need that much anyways? Even with the best turbo on the market and proper tuning I think that you would burn the unit up rather quickly. Just buy an STi ! ~C.J.~ DensoSupra 08-29-2003, 07:28 AM Can an '03 WRX withstand 24 psi boost (with an aftermarket turbo) without exploding? Definately not on a stock bottom end. 24psi is testing the limits of pump gas. ScoobySnacks 08-29-2003, 09:39 AM Quote: -------------------------------------------------------------------------------- Originally Posted by darkaccord Can an '03 WRX withstand 24 psi boost (with an aftermarket turbo) without exploding? --------------------------------------------------------------------- All I can say from years of messing around with Turbo cars is that 24psi of BOOST on a stock motor without ECU/Internals?Fuel mods= KABOOOOOOM! Scobb Doo :nono: EJ20 08-29-2003, 07:41 PM 22psi for 40k miles now. I will be in 24 psi with GT30 turbo in about one month. It can be done, UTEC and STi injectors are needed. Burnit_420 08-31-2003, 03:10 PM In my opinion, thats suicide running a stock WRX on 24 PSI. If you want more horses, just start out with stuff like exhaust, intake, new PCM, etc. 24 PSI is too much for street use anyways, unless your dragging vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
