99 Silverado ext cab wind noise
Google
Web AF
anthonyball
08-02-2003, 01:57 PM
Does any one know how to stop the wind noise around the extended cab side vent windows. The latches seem flimsey and loose, can these be repaired, adjusted or replaced. The weatherstripping look intact, but maybe it's worn out/dried out/compressed to the point that it needs replaced, can the weatherstrip be easily replaced? This is my first chevy pickup and I like it, but the wind noise is too much.
lmnmarang
08-03-2003, 09:46 PM
take it to a gm dealer they have screws they can put in the latch itself what it does is draw the latch closer to the window frame creating a tighter seal sounds cheesy but it works,the only other option is to have the window and latch assembly replaced($$)the repair with the screws should no more than an 1hr and whatever the shops labor rates are plus maybe $2.00 for parts good luck
anthonyball
08-04-2003, 05:19 PM
Is the screw repair procedure something I could do myself. If so were could I find specific instructions.
lmnmarang
08-06-2003, 07:50 PM
i'll see if i can find any pictures on the repair and e-mail them to you
dhughins
08-06-2003, 08:57 PM
I have the same problem on my 2000 ext. cab
amcinerney
08-08-2003, 01:12 PM
I have the same problem in my 99'. Have you ever taken it through a car wash? I have, and my cup holder gets filled to the rim with water from the passenger side rear window.
Dealer said they couldn't reproduce it (with a garden hose)...Wouldn't fix it.....! I just stick some paper towl in the cup holder now when I go through the wash.
gonetobama13
08-13-2003, 01:12 AM
Do you have a bug deflector on the hood? If so, you might try removing that and see if it helps. It can't hurt.
John K.
Dihappy
08-21-2003, 05:44 AM
There is a TSB about this and i had my rear windows replaced under warranty.
If your outta warranty then youll have to spend some money.
LaTruckScene.com
08-21-2003, 03:10 PM
The best thing to do is to bring it back to the Chevy dealership, this happens a lot and they will fix it. It is a factory defect.
djpbaby
08-26-2003, 09:42 PM
Here is the actual bulletin on the crappy window design. It is only good news if your vehicle is still under warranty cause the window is over $170.00 bones.
Wind Noise from Body Side Quarter Window (Replace Body Side Quarter Window Assm) #99-08-48-001A
Wind Noise from Body Side Quarter Window (Replace Body Side Quarter Window Assembly)
1999-2000 Chevrolet and GMC C/K Extended Cab Pickup Models (Silverado and Sierra)
Built Prior to February 1, 2000
This bulletin is being revised to add the 2000 model year, remove service procedures, and change the part numbers. Please discard Corporate Bulletin Number 99-08-48-001 (Section 08 -- Body and Accessories).
Condition
Some customers may comment on wind noise coming from either of the body side quarter windows while driving with the quarter windows closed. The wind noise may be more noticeable at speeds over 56 km/h (35 mph).
Cause
An insufficient seal of the window frame to the body or an improper window latch length may cause this condition.
Correction
A new body side quarter window kit is available to correct this condition. This window kit includes the window frame and glass, three frame centering screws that reinforce the sealing of the window frame to the body, and an instruction sheet. The window frame also features a reinforcement latch tab to improve latch efforts and function.
Replace the applicable body side quarter window on affected vehicles. Use the appropriate part number listed below.
Refer to the applicable Service Manual for quarter window removal and additional installation procedures. Also refer to the instruction sheet provided with the window kit for installation information.
I haven't tried any homemade remedies yet, but that's the only way I know to fix it.
KRAZYMATT36
09-13-2003, 07:30 PM
ughhhh not the news i wanted to hear (mines out of warrenty) but ok. i was hoping it was just maybe a latch that could be replaced.
-krazymatt
trukdryver
09-14-2003, 01:27 PM
KRAZYMATT-
This may sound way too simple, but my '00 Z71 has a slight wind noise from the passenger rear area, too. It seems more prominent when the wind is coming from the driver's side. My fix is to turn the heat/ac to "recirculate"... I don't know if my problem is the window or the weatherstrip where the two doors meet, but simply setting the heater to recirculate gets rid of the problem for me. There is no noise from the driver's side quarter window, so the thought of the windows being bad never crossed my mind!
KRAZYMATT36
09-22-2003, 09:33 PM
thanks,
ill give it a shot this week.
-krazymatt
herbs
10-30-2003, 10:54 AM
I had the same problem on my 97 z71, since I never used the side windows i went to the hardware store and got some 1/2" foam tape and applied it to the window to where it would seal against the factory weatherstrip, problem solved
bim
10-30-2003, 12:43 PM
Before spending any money I would simply take the latch apart and put it back together. Most likely a screw or two loosened up and all you have to do is tighten it up and use blue loctite so that it doesn't back out again. This is at least worth a try before you start spending money, and a tube of loctite is only $3. Keep us up to date.
penguins1
12-01-2003, 09:22 AM
Has anyone come up with an easy fix for this? My 99 does the same thing. I do have a bug deflector on it which I need to remove to see if it helps. Anyone else have any advice?
Thanks!
kan_man
01-06-2004, 05:00 AM
so honestly what is the best way of solving this annoying noise and actually fixing the problem??
earlytimz
02-08-2004, 05:26 PM
blue comic I've got a '99 4X4 that was doing the same thing. I popped off the window latch and switched it with the driver's side. My problem followed the latch. I then inspected the latches and noticed that there was a small plastic tab inside the latch that had been bent over and almost broken off. I put a dab of super glue on the tab, bent it back over so it was stright (being careful not to break it completely off), held it in place till it was dry, and that fixxed the problem. I left the repaired window latch on the driver's side since I only have 3 doors and most backseat passengers end up staying on the passenger's side. I figured it would get less use on the driver's side and be less likely to fail again. That's been a year ago and I've not had a problem since. Good Luck!
Google
Web AF
