Aftermarket headlights - where to buy???
joneblaze
07-31-2003, 02:52 AM
hey fellow aussies,
im back with a few more questions.
i wanna change the stock headlights on the teg to the aftermarket "white" Xenon type lights. Does anyone know what a good quality brand is, where to buy from and how much they retail for? I'm not after the shithouse fuzzy whitish bluish ones, i'd like to get as clear and white a light as possible. I know it's not going to look anything like a euro luxury HID system, but i'd like something bright and clear that looks good. I know that places like carmate, autojoy n motoquipe, etc stock them. Can anyone recommend a particular brand??? (I'm in sydney) Also, where can i get lil ricey blue/white lights for my plates? hehe...
cheers,
j.
p/s: can anyone point me to a site where i can find out specs for my 95 gsi? i've looked everywhere and can only seem to find ones for type r's etc. im specifically looking for the power specs, 0-100 and 1/4 times for the stock 95 gsi. thanks
Spunkymonkey
07-31-2003, 09:53 AM
why do you want to bother changing the lights for. Teg lights are quite bright, and the high beams, are enough to blind you.
ah..I can see we have a rice boy in the making....you mentioned carmate and autojoy :lol:
In terms of specs for the gsi. :rolleyes:
Cmon...do some research here!
go to www.carsales.com.au
click on the compare section, and pop in the model of car. It brings up the specs..
joneblaze
08-03-2003, 10:14 AM
well spunky firstly my teg headlights suck... although ill agree to the blinding qualities of the hi beams :tongue:
i went to www.carsales.com.au and clicked on compare... under honda i cant find the integra, ive searched the web for my model specs and all i find is stupid acuras....
sooo... back to my first post. help?
Spunkymonkey
08-04-2003, 05:50 AM
your hopeless aren't you :biggrin2:
you didn't follow the instructions on the website?
Here it is...copy and pasted.
Dimensions
Length (Mm) : 4395
Width (Mm) : 1710
Height (Mm) : 1335
Wheelbase (Mm) : 2570
Track - Front (Mm) : 1475
Track - Rear (Mm) : 1465
Weights & Capacities
Kerb Mass (Kg) : 1146
Tare Mass (Kg) : 1075kg
Seating Capacity : 4
Luggage Capacity - Seat Up (Litres) : -
Towing Capacity - With Brakes (Kg) : 450kg
Body
Body Construction : Monocoque
Openable Roof/Canopy : -
Engine No Sample : B18B2 1234567
Vin Sample : JHMDC43500S000001
Engine
Engine Code : B18B2
Engine Location : Front
Engine Orientation : Transverse
Engine Description :
Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, all aluminium alloy, cross-flow head, cast-iron cylinder liners.
Capacity (Cm3) : 1834
Fuel System Type : PFI
Maximum Power : 101kW @ 6300rpm
Maximum Torque : 172Nm @ 5200rpm
Cylinders : 4cyl
Valve Train : DOHC
Valves Per Cylinder : 4v
Block Material : Aluminium alloy
Head Material : Aluminium alloy
Compression Ratio : 9.2:1
Fuel Type : 91 RON ULP
Fuel Tank Capacity (Litres) : 50
City : 8.5
Highway : 6.8
Steering
Steering Description :
Rack and pinion with variable power assistance.
Turning Circle - Between Kerbs (Metres) : 10.6m
Brakes
Front Brake Description : Ventilated discs
Rear Brake Description : Discs
Suspension/Front Description :
Independent, double wishbones, strut type spring/gas damper units and anti-roll bar.
Suspension/Rear Description :
Independent, double wishbones, trailing arms, strut type spring/gas damper units and anti-roll bar.
Tyres & Rims
Front Tyre Description : 195/55 R15 84V
Front Rim Description : 6.0JJx15
Rim Material : Alloy
BoneZee
04-24-2004, 06:39 AM
Auto Joy and Car Mate.
