z32 engine swap
Hereik
07-24-2003, 07:06 PM
hey i'd like to hear some pros and cons for doing an engine swap for a n/a 90 z32 manual....i was thinking about trying to find a good skyline engine that would be compatible for twin turbos...is this possible? (i know anythings possible but hey when's the last time you saw a big block in a model T????)
peaceamahalo:sunglasse
gottem
07-30-2003, 01:00 AM
skyline engines are i6's, so basically, unless you want to spend ALOT of money into moding the car (moving the firewall, and alot of other things in the engine bay), only real choice is a vg30dett, which will still be expensive depending on if you can do it or not. if you can do the entire swap, it will still cost a bit, but would be the cheapest swap.
