Check Engine Light Comes On
Google
Web AF
BBRGARDNER
07-22-2003, 09:51 PM
The "check engine" light comes on in my 91 Honda Accord SE once I start driving. Also sometimes the engine turns over but will not start until I let it rest and then sometimes it will start. I had a new distributor installed but the problem continues. Today I bought a new battery and the saga continues. Any advice would be greatly appreciated. Thanks
DIRTYDAWGS
07-23-2003, 03:32 PM
try unpluging the mas flow sensor the replug it in it should run fine after http://files.automotiveforums.com/uploads/522023Webmfs.jpg
HONDA_99
07-23-2003, 07:20 PM
4gen accords are known for having problems with Main relay and Ignitor problems. so most likely its one of them giving you a problem.
search accord forum (not Accor V6 forum) and you find what to do.
HONDA_99
07-23-2003, 07:23 PM
it would work, if it had one.
most of Hondas don't have MAS, they use MAP. MAP located on throttle body, and not in air intake tube like MAS.
BullShifter
07-24-2003, 01:45 PM
many things can cause a check engine light to come on. find out what code it is, then it will be easier to help you.
lorunner
08-21-2003, 07:39 PM
Ahh I think your looking for the nissan forum :confused:
Google
Web AF
