Painting a car Flat Black
malsheem
07-19-2003, 12:36 AM
Has anyone ever painted a car flat black or any flat color for that matter?
I'm building an R32 GT-R and I was going for the same look of Sport Compact Car's Project Silvia which they painted flat black. It looks good, no-nonsense, no fluff, all business kind of look. I'm just not sure if it would work out well on a model. I don't want to paint it and find out it looks like crap and start over.
freakmech
07-19-2003, 12:51 AM
That Silvia does look good and that was spray paint! can you believe it? they had a tutorial on how they did it. anyhow you never know till you try but heres a suggestion. go ahead and paint your car flat black... if it looks bad then just pretend it was a primer coat and spray a dark gloss color over it! but flat colors always go on much more even then gloss so it should be easier. but might not be as smooth and you wont want to sand it so youll want to use a flat clear coat that you can buff for a smooth finish. thats all there is to it! hope this helps
IwannaDRift
07-19-2003, 01:32 AM
http://files.automotiveforums.com/uploads/454653Picture003[1]
Heres a picture of my R32 GTR in Flat black, its not done...
primera man
07-19-2003, 04:49 AM
The pic is not working.
You have to get a very even coat of paint on the body to get a good flat finish or it can dry in slightly different shines.
IwannaDRift
07-19-2003, 05:54 AM
damn, my pics are weird I guess, I followed the directions(i think), but anyways, I did my R32 in flat black and it is made to be a drag car, it looks cool (imo) and just try it... If it doesnt work,,,,, brake fluid... heh
modelcarmaster16
07-19-2003, 10:20 AM
will this work
http://www.automotiveforums.com/img...54653Picture003
RaceMySS_454
07-19-2003, 10:51 AM
if you paint a car flat black, than put a clear coat over that, How will it look??? like a semi gloss???
sugarcaddy
07-19-2003, 11:23 AM
Well you can use a flat top coat instead of a gloss. Try Floquil Figure Flat in the spray can. It works great as a flat top coat finish.
Scott
willimo
07-19-2003, 12:06 PM
I've painted a couple cars flat colors, a couple primer rods from the Revell kits. Quick and dirty builds to burn off stress during exams. Anyway, on those cars it looks hard core. One I used Krylon Ruddy Brown primer, and on the other I just used Testors flat black from the spray can. I was worried about it coming out in different shines, and also about the oils from my skin colelcting on the paint and making it have different textures. Niether of which happened, the paints both went on super smooth, and though I don't handle them much, the little I do hasn't left any greasy prints so it seems A-ok. I'd just go for it, it'll look sweet. And if it doesn't, eh, it'll just be an undercoat.
hobbes874
07-19-2003, 12:15 PM
Might as well paint it semi-gloss :dunno:
Flat black is going to be impossible to polish unless clear coat is used.
Jumpman_Z
07-19-2003, 01:15 PM
Another thing to try is to go through the whole process of priming and painting the car gloss black, and then lightly sand it so that the paint is dull, then spray dull coat/flat coat on it. I usually do this with the interiors when I want a special color that doesn't come in flat, and it turns out pretty good. If you do this, it might be a good idea to prime it with black primer. That way, it'll be okay if you sand through the gloss black.
themodelkid
07-19-2003, 03:12 PM
Thats a big negative! Automotive base coats, (the color) that we use at the shop, are all flat drying, once you put clear cote on it then it will be glossy, so if you put clear cote over flat black it will be just as shiny if you sprayed a shiny base under it. Just spray the flat black exactly how the P-man said, nice and even an at a steady speed and it should come out good.
malsheem
Thanks for all the tips. I primed the car last night. Once that's set in properly and my can of Tamiya Spray flat black comes in, I'm going for it. Hopefully it turns out good.
calvin3
07-19-2003, 07:15 PM
Kinda off topic buuuuuut I painted this R/C body using ModelMasters Flat black spray paint....I painted the outside to get the flat look. enjoy
http://home.attbi.com/~yadayadaya/images/flamedford/flameford2.jpg
freakmech
07-20-2003, 03:05 PM
does anyone here read posts before putting in there 2 cents??? i did say use a FLAT CLEAR COAT, and yes lots of companies make them. also SATIN type clear coats go on flat as well. please read all responses before try to reply... you make things very confusing. my response was very clear as to what to do if you simply read it. sorry but there are so many redundant posts here where people ask questions in a thread that have already been answered.
