Rotary in an MGB, or other possibilities
Google
Web AF
ViolentBlue
07-13-2003, 01:31 AM
I'm sure this has been done, but would you consider it a bastardization of an MGB?
I'm seriously considering buying an MGBGT as a project/race car and of course the stock 4 banger has to go, I'm looking into other possibilities for motivational power.
I'm a VW guy and in VW circles its considered sacrilige to put anything other than a VW engine in your VW. Now I know the lines between makes of the british cars are a little fuzzy, and when it comes to swaps the lines are often trampled on, but would a rotary, or a BMW I4 or 6 be out of line?
what other engines out there are good for this swap (Don't really want to do a V8, I want something quick and nimble with enough power to make those fart can hondas feel silly)
ViolentBlue
07-18-2003, 12:14 AM
does no one even come in here anymore?
ViolentBlue
07-31-2003, 02:26 PM
I'm thinking a DOHC Supra Inline 6 might be a nice engine to go in this car. What do you think?
denny411
08-14-2003, 02:49 AM
Have you considered the Bonneville SSE supercharged 3.8? Supposedly they will mate perfectly with the 700r4 from a late 80`s firebird or camaro with the 2.8v6.
It wouldn`t wiegh much more than the original drivtrain because the heads,intake, and transmission are all aluminum.
I`ve been considering a similiar swap but I haven`t made any definate plans.
I`ve also considered using the drivetrain from a thunderbird turbo coupe. I could even have the posi 8.8 rear narrowed to fit. (they come with rear disc brakes)
denny411
08-14-2003, 02:56 AM
BTW, I suspect that your previous posts were not answered due to the nature of your question.
I`m sure the majority of the members here are somewhat offended by your intentions to "bastardize" or "hybrid" your beloved MGB.
I personally hold no loyalty to any manufacturer. I choose to own vehicles for certain aspects that I like. What I don`t like,I change.:wink:
ViolentBlue
08-14-2003, 02:29 PM
I'm more a fan of european engeneering, but I have a friend who loves toyota's, since I wanted a I6 with DOHC he suggested the supra engine. I personally would consider BMW (who owns the remnants of MG if I'm not mistaken)
but this is all a side issue now, since I passed on the oppertunity to pick up the MGBGT that I was inwuiring about.
denny411
08-14-2003, 03:33 PM
In my opinion, the engine compartment in the mgb is too short for an inline 6. It might be posible if you delete tha heater core and fan blower housing, but I still think you would have to give up some leg room. Otherwise the engine would be too far foreward and it would kill the handling of the car.
Moppie
08-15-2003, 11:44 PM
There were a limited number of MGBGTs made with the 3.0 Austin 6 in them, and if that will fit then anything will.
Unforunatly its so heavy the car handled like even more of pig than it did orginaly.
The Rover v8 is by far and away the best swap, all the parts required can be easily sourced, and there are so many people out there who have done it that advice and how to's are easy to find.
The engine as well being capable of making more than enough power is also lighter than the old A series, so it makes a marked improvement to the cars handling as well.
But if you want something a little more modern, then a Toyota 3sgte, or Nissan SR20DET are both great engines, but you need the Turbo'd versions to get enough useable hp to make the car move. This means added complexity, something you want to try and avoid on something as old as B, unless of course you prefer working on the car to driving it.
Hudson
08-18-2003, 11:42 AM
Actually, the MGC is the MGB with an inline six. The engine was heavier than the four-cylinder or V8 engines offered in the B and did affect handling. The engine was a 2.9L (2912cc) version of the six-cylinder found in other cars (the Austin-Healey 3000, for example).
I'm sure that one of the modern DOHC inline sixes would be too tall to fit under the hood of the B or C (the MGC had a small bump on the hood because of the longer engine.
I agree that the Rover V8 is the way to go. It's offered in many states of tune from the factory including carbureted (both from GM and Rover) and fuel-injected versions. Land Rover still uses the engine in the US in the Discovery.
Corgitoysaver
02-08-2004, 10:37 AM
Rover K-series engine. 130 BHP, lot's of torque in a much lighter B then the car you'll get it from, and, less fuel consumption than the old 1800.
Raymond.
63mgracer
06-18-2004, 12:51 AM
12a rotary motor works perfect.....mine is race ported with about 230 ponies....mazda 5 speed tranny....posi trac(welded spider gears)...13X8 wheels on front, 13X10 on back(3 piece racing wheels)....griffin race radiator, 13b oil cooler, dual downdraft weber carbs, racing beat intake, racing beat header, full roll cage bumper to bumper, f1 steering wheel......installing panhard bar this week and upgrade ignition soon
turbobob
07-01-2004, 05:07 PM
Hey 63mgracer, can I get some details on the Rotary conversion? I have a 70 MGB that needs a new drivtrain and I am leaning towards the mazda just because I allready have a Pro7 RX7 and some extra motors.
Thanks
Turbobob
63mgracer
07-01-2004, 11:00 PM
a 12a motor w/a mazda 5 speed will fit right in. Use the rx7 motor mounts...just put them on the motor first and then drop it in to mark where you need to drill.....if you can find a 81-85 mazda pick up tranny and use the rear half to mount to a rx7 bell housing...you wont have to cut your transmission tunnel...otherwise some motifying will have to be done...and a custom drive shaft will have to be made....you wont be able to use the stock fan as it would stick up out of the hood...a griffin radiator for a vw sirrocco fits nicely...i will take some pics soon and put them on so you can see the car and the motor...
turbobob
09-02-2004, 04:46 PM
63 MGracer:
I will starting my MGB to Rotary conversion in October. Do you know if a 13B with fuel injection will fit? Have you had a chance to get any of the pictures that you mentioned? I would love to hear more about your conversion.
Thanks
Turbobob
whatcha/got/racer
09-03-2004, 03:42 AM
turbobob ay i have an mgb and i was planning on swaping motors could i get some of that info thanks.
adam9090
10-11-2004, 04:07 PM
You can put a supercharger that will bolt right no if you are looking for more power or you could do an engine swap. An inline V6 isn't gonna fit too easily if at all, look at the MGC. I used a 60 degree v6 which worked out great and I've also seen the 90 degree v6's going in these cars. the rover/buick/olds aluminum v8 will fit many people have done it but it is a harder fit and not as much power as the v6's. any 4cylinder will fit and i've seen some nice ones with turbos like a ford 2.3 turbo. 302s will fit i've seen a few people doing that. go to http://www.mgbexperience.com/phorum/list.php?f=40 for a great v6/v6 mgb forum
Great-King-Rat
10-27-2004, 09:14 PM
I agree with what denny411 said...if its my car and I dont like it...Ill change it. I have a '73 MGB convertible and would like to take the 4 banger out and rebuild it and replace it with a low power V-8...maybe 3.4 liter or something and add a dual sports exhaust and and try and take on a Cobra effect. Ive done nothing yet...just a thought.
irnwoodyhead
11-10-2004, 08:14 PM
I' stuffing a 2TC 1600 cc into my GT. It's in and the motor mounts have been built. It's got the 2 weber doce40's mounted. I'm working on the header now. When I close the hood,(if it fits over this engine) no one will know that the engine was replaced.
irnwoodyhead
irnwoodyhead
11-10-2004, 08:18 PM
I have a 1974 getting a 2TC. Its in and the 2 weber dcoe40's are on I'm working on the header right now.
paul J
02-17-2008, 05:01 AM
MGA Rotary, why not a "B"?
http://i58.photobucket.com/albums/g273/PJ161/JonathanLamson-C.jpg
http://i58.photobucket.com/albums/g273/PJ161/JonathanLamson-B.jpg
http://i58.photobucket.com/albums/g273/PJ161/JonathanLamson-A.jpg
Tayyab
03-28-2008, 12:41 AM
Hi, This post of yours is very beneficial and informative, however there are some specific facts or information that I require. If anyone can help me in this matter then please send me a private message. Best Regards,
paul J
03-30-2008, 11:11 AM
The problem that your most likely to run into is, not many, if any, MGBs have been converted to a rotory engine and to get the specs that your probably looking for are more than likley non existant. I've never heard of that MGB conversion. Your probably going to have to tread in uncharted waters if your so inclined. I doubt if you could use MGA specs. MGAs and MGBs are two different animals.
olbear
03-30-2008, 05:34 PM
I put a Ford sohc 2.3L in my 1976 MGB roadster with a 5 speed behind it. It fits using the unmodified MGB driveshaft. The engine barely clears the steering rack in front and the stock firewall at the rear. Currently it is carbureted with a Racer Walsh cam and a few thousandths off the head.
The hood closes (barely) with no scoop - its a sleeper. There is room to add a turbo in the future if more hp is needed. It is a reliable, FUN CAR on the Colorado mountain roads.
paul J
09-03-2008, 07:37 AM
FOUND ONE! Old issue, but I thought I'd up date it a little. Here's a
rare 100 hp conversion of a 1975 MGB to Rotary power. The only one that I know of. The cars a mess and the wiring looks like something out of a spaghetti factory, but it shows the conversion can be done. Click on link. MGB with Mazda Rotary (http://www.plesba.com/images/mg/)
Google
Web AF
