Front left corner light deadmengy 07-08-2003, 06:53 PM the bulb is fine, the wires are connected... can there be a fuse somewhere that is dead? When i signal left, it blinks really fast... i think cuz it thinks the bulb is burnt out mengy 07-08-2003, 06:55 PM i have a 93 dx civic hatch I lost the panel that tells what the fuses are... anyone know where i can find it online? but then i checked all the fuses under the dash on the driver's side.. none of them that were there were burnt out.... i say this because the previous owner probably took some out.. whiteracer 07-08-2003, 07:17 PM the relay box type thing under there all the way in? If you buy a hyperflasher, the black box is altered to make it flash faster. That's my only guess, in which the fuses would look ok, but the flashing controller would be out of wack. :confused: mengy 07-08-2003, 08:17 PM well i wouldn't care if all it did was blink fast.. but only the left side blinks fast... and it doesn't come on at all.... but the bulb is fine cuz i switched the left and right and still left side dead. I don't have a hyper flasher relay whiteracer 07-08-2003, 08:30 PM hmm. weird coincidence, i just had to move my car so a co-worker could get her 93 dx hatch out.... No, even if you don't have a hyper flasher relay, there is still a little plastic black box that makes sound when the bulbs are flashing. Its responsible for the familar "click click, click click,..." Try taking that out and putting it back in after a few minutes. mengy 07-08-2003, 08:34 PM hmmm i will try that.... and i will post results... thanks.... there is 2 though... whiteracer 07-08-2003, 09:03 PM invest in a helms manual or at the least, the manual for your car that it should've come with. Take them both out, and put them back in. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
