tubo or charger on a 89 nissan maxvalvenus0214 11-16-2001, 11:24 PM guys maybe you can help me out. i need to know if you can install turbo or charger on a 89 nissan maxima. if yes, just give me some info on specs. thanks alot PEACE! Seb928S@af 11-23-2001, 03:29 PM WTF this is the porsche section go somewhere else richboy! Cbass 01-12-2002, 09:13 PM I agree with buddy here. Go rice burn somewhere else. I'll still help tho. You can turbocharge anything. It's easy. Start with the mechanincal side. You'll need to find space to put the turbo. You'll need to get a custom turbo header to feed exhaust into the turbo. You'll probably want an intercooler to prevent detonation at high boost levels. If you plan on running over 8 pounds of boost, you'll need low compression pistons. If you have an EFI engine, such as a maxima's, you may want to have an electronically controlled turbo. These make a world of difference, because you can set your peak boost to kick in at 2500 rpm. You may want to take the neccesary equipment off of a 300zx turbo, because it uses the same basic engine(the VG30e) as your maxima does. Using the 300's ECU will allow you to control the turbo properly. The two hard parts are making the turbo fit in the engine bay and finding space for the intercooler, and doing the wiring. The wiring is the really difficult part. If you do a mechanical turbo charging job, it won't be as smooth, but you won't have to worry about wiring at least. It'll be a lot cheaper too. Damn, I just know everything.:cool: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
