Interior painting
x007den
07-08-2003, 02:04 AM
Im looking into painting some of my interior, what kind of paint should i use and whats the best way to go about it?
whiteracer
07-08-2003, 02:06 AM
Krylon. Used for interior and exterior of your car. Where near l.a. you from?
SilverY2KCivic
07-08-2003, 04:26 AM
I thought i was the only one that did that.... LOL! j/k man. :tongue:
Swonder67
07-08-2003, 12:42 PM
Don't forget to wash all the pieces you are gonna paint THOROUGHLY!!! All those years of Armoral left a nice thick coat of grease on the pieces, if you try to spray the paint directly onto the pieces without washing them, the paint might not stick in certain places... Also, after washing the pieces, you could spray them with Adhesive Promoter (available at most auto parts stores). Adhesive promoter is a clear spray, kinda like a primer, it'll help the paint sick to the pieces and it will leave a more even spray.
BTW, I would use krylon too.
whiteracer
07-08-2003, 01:30 PM
don't even say it Matt. :dogpile:
SilverY2KCivic
07-08-2003, 03:05 PM
Nope, never done that step in my life! :bigthumb: :icesangel
haha, naw. I've painted up some of my interior junk. All I did was wash up the pieces real good. Maybe even wiped down with some rubbing alcohol, then sprayed on 2 coats of Bulldog brand adheisve premotor perpiece, letting 20 minutes between coats to dry. Then sprayed on the Krylon paint I used. 2-3 coats. I know that seems thin, but almost a year later, and no flakes or chips yet. Can always be touched up if need be, or stripped and then the whole process redone. I opted NOT to sand the pieces incase I were to ever want to restore them back to stock look.
BTW, the Krylon I used on my interior stuff is the SAME Krylon I used to paint my OEM sideskirts over 2 years ago. Not a single chip or flake off of those yet to date. I did prep those quite a bit different though them being an externally mounted piece. I 220 grit paper wet sanded them down to a dull gray finish, washed them down, then began an almost half day paint process. Used 5-6 coats of paint on them, and 3 coats of clearcoat. Especially for external pieces, prep work is the MOST important step, and will make or break the quality of the work and how long it lasts.
VTWanderer07
07-16-2003, 02:52 PM
any suggestions for clear coat brands out there?
Cobrakessen
09-01-2004, 10:56 AM
If you did want to restore your interior back to stock how would you go about doing that.im thinking of doing the same but with a clear coat on it as well.but the option would be nice to restore to stock,and let me breath alittle easier while painting if its easy to reverse,especally if it ended up looking bad and ending up like this guy --> :banghead:
Darb 2k
09-01-2004, 11:59 PM
yea i need to touch up a couple places, how would i go about it? just paint right over? suggestions? its chipped a bit but not too bad, and i need to clean it too, any suggestions to cleaning painted plastic interior peices?
Ricochet
09-03-2004, 12:02 AM
New record! This thread is 14 months old!
Jas_M
09-03-2004, 01:09 AM
That's nothing, check this one out: http://www.automotiveforums.com/vbulletin/showthread.php?t=16053
Ricochet
09-03-2004, 05:43 PM
holy crap, guess that one takes the cake..
