96 Silverado Hard Starting
Google
Web AF
glbell62
07-07-2003, 11:34 AM
1996
350,5.7
After putting everything back together after replacing the intake manifold gasket the engine is very hard to crank but every once in a while (4 or 5 start attempts)
it starts perfectly and runs great, but if I turn it off it goes through the same thing again hard cranking.
Is it possible the rotor or distributor is on backwards? (I changed the rotor and am pretty sure I put distrubutor back in same spot but just trying to think of what it might be or would it not start at all if this was the problem.
Would a crankshaft position sensor cause this behavior? I don't have andy code testers but would go get one if this would help diagnose.
I am trying to narrow down the possiblilities before taking it in for a diagnosis.
Any suggestions would be great
Gary
louisanagambler
07-12-2003, 12:42 AM
BUY A NEW TRUCK, ITS THAT SIMPLE
lynntrull
03-17-2009, 12:33 PM
If the engine is out of timing this will happen. Most of the time when you take out the distributor, even if you mark it, you have to have a scan tool than will display the cam position offset to set the cam position sensor to 0* +/- 2*.
lynntrull
If the engine is out of timing this will happen. Most of the time when you take out the distributor, even if you mark it, you have to have a scan tool that will display the cam position offset to set the cam position sensor to 0* +/- 2*.
ROBERzo
03-18-2009, 01:27 AM
hi, main is 2001 was too hard to start, I dicovered that fuel pump was not holding presure; just change hose betwin pump and module and is working fine. good luck
Google
Web AF
