Replacing outer crank seal & Timing Belt....
Google
Web AF
vassil3427
07-02-2003, 09:51 PM
I have a 1995 Lumina, its continually leaking oil from the outer crank seal behind the pully, how much of a problem is it to replace that seal and gasket?
pcv
07-03-2003, 09:39 PM
Replacing the crank seal takes about an hour. However, I'd check the front cover and make sure the gasket is not leaking, especially above the oil filter housing. I've has two that leaked at the same area. Good Luck.
Google
Web AF
