1999 Monte Carlo LS Turn Signal switch?murphturph 07-02-2003, 04:07 PM I have a 99 Monte Carlo LS with nothing in the steering wheel. (no radio etc.) The turn signals work (intermittent) when I pull them slightly to the high beam direction. They stopped working in the normal fashon. Is there a fix while it's in the column? Or Do I need to pull the steering wheel to replace it? Is so, How do I do that with an air bag? Thanks Murph in Tucson. :bloated: Montelookup 12-22-2003, 04:22 PM I have a 99 Monte Carlo LS with nothing in the steering wheel. (no radio etc.) The turn signals work (intermittent) when I pull them slightly to the high beam direction. They stopped working in the normal fashon. Is there a fix while it's in the column? Or Do I need to pull the steering wheel to replace it? Is so, How do I do that with an air bag? Thanks Murph in Tucson. :bloated: Get 2 new bulbs for your taillights. They (signal,stop,backup lights) are all the same bulb. They are cheap about 3 bucks for 2. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
