BRAKE light in dash blinking in sequence... WTF
Google
Web AF
Dave ESPI
06-30-2003, 11:58 PM
I have an 89 Chevy Astro Van. No anti-lock. The dash light has been SOLID RED oand on for like months since I had brake work done on the right rear. THey replaced a brake piston and plungers for the drum (non disk rear). I thought that there was some dirt cloging one of the sensors inn the master cylinder ( as this had happened before) and I was NOT paying 89.95 for a BG Brake Service flush. SO ! the truck was fine for inspection, and no fluids appear to be leaking, and all the brake parts are dry.
I checked the manual, nothing there about codes.
It blinks 6 times for a second each blink, then is steady for 2 seconds for the 7th blink.
Any ideas?
I don't think the level is low in the Master Cyl.
(ill check tomorr ) its dark outside and there are wolves that want to eat me .
thanx.
Draggyn
07-29-2003, 05:18 PM
My 89 Astro has similar problems except i get 5 short 1 long> I was wondering if there was a readily available site to check the error codes?
ALSTRO1
01-08-2006, 04:57 AM
hey i got the same problem, trying to figure it out? i just did my brakes, and the light turned off after i did them, and then went back on? wtf? gotta check the fluids again, but it's funny cause we all got 89's..
brcidd
01-09-2006, 08:09 AM
After a brake line bleed- there is a "reset light" procedure outlined in the service manual- very simple to do- I do not have my manual in front of me- will try to find it and post-- I had a guy with the same problem come to me about 3 yrs ago- and I was able to reset his light.
Kings-x59
01-11-2006, 11:13 PM
Hmmm. I didn't run into this problem when I did the brakes on my '89, and mine does have rear abs. My manual lists no codes for brakes at all. The first thing that comes to mind is that perhaps the parking brake needs adjusting.
jarmstrong44
01-21-2006, 03:35 PM
I have had the same problem, 5 short and 1 long. I have not work on my brakes. I did unhook my battery and hooked it back up, and the light is now out. I would like to know what it means.
Google
Web AF
