error code P0106
spmurphy_no
10-30-2015, 03:45 PM
I have a 2001 Camry, and the check engine light went on. It came up the first time as miss fire. So, I gave it a tune up. The engine light came on again with P0106. I replace the map sensor. The replacement would not fit the old harness. So, it is just hanging there. I will order the new harness today for the map sensor. I un plugged the battery and the light went off. It came back on with P0172. What needs to be done now?
somick
10-31-2015, 10:20 AM
The fact that the MAP sensor did not fit tells me that it may not be recognized by the ECM.
If you left it hanging there there might be a hole in the air intake. That is why you may be getting P0172 code.
Before buying a new MAP sensor I would attempt to clean the old one.
YouTube is full with the videos on how to do it.
Try it first.
Good luck,
Sam
Try it first.
Good luck,
Sam
