Page updated on 07-21-2018
Tamiya 911 GT2 instructions - glass
willimo
08-12-2015, 05:14 PM
http://img.photobucket.com/albums/v417/willimo/10022667z5_zpsv2mtfhwm.jpg
The instructions are usually pretty clear, but I am not sure how to paint the glass here. The instructions seem to clearly show that I should paint the inside, but the molded relief is on the outside. What do y'all do?
Veyron
08-12-2015, 05:25 PM
I painted inside as usual and didn't really consider painting the outside.
sprite46cfk
08-12-2015, 05:46 PM
I'm just about to paint my GT2's rear glass also and am looking for a good masking technique to address the tight radius at the corners. Any and all suggestions welcome.
Chuck
hirofkd
08-12-2015, 06:06 PM
You paint both.
On the inside, you paint the area between a very fine line and the outer circumference of the window part. That's where the real car's window is glued to the body.
On the outside, you paint the relief. That's a sealing rubber, and it's usually the same material as the ones marked as X-18 in Step 11 of the instruction.
(You don't necessarily have to use X-18 Semigloss black. It's too glossy to my taste.)
I usually use a permanent ink pen to do the corners, and use a french curve to do the border lines because I have much better control with a pen. (Then I paint the rest with a brush.) You can even cut out a curved template out of a styrene sheet.
willimo
08-12-2015, 10:09 PM
I think my confusion came from the very weak engraving for the inside, painted window trim. I can barely see it, in fact I missed it the first time and am having to spray again.
For the trims, I like to use wide Tamiya tape across the whole glass, and cut away the outside so I just mask off what is clear in the center; the result is a lot like what most Japanese companies include in their kits these days. I often use a Zig pen (just happens to be the brand I have) to mark a wipe-off-able blue line before I put down the tape. I can see it through the tape for cutting, and what the paint doesn't cover, the tape lifts off.
stevenoble
08-12-2015, 11:50 PM
For corners I use Tamiya tape and punch circles in it using a punch and die set. I stick a circle into each corner and fill the space between them with straight pieces of tape..
