Scale Motorsport metal sticker rivets any good?
joelwideqvist
01-04-2015, 02:31 AM
Continuing my question monologue :-)
I want to do a pimped set of rims with perimeter brake disc and a contrasting set of rivets all around the rim. It will take quite a lot of rivets though, almost 150 pcs... The rims are going to be black or maybe gun metal/metallic grey so I want golden rivets.
Now to the actual question... Drilling 140 holes seems a bit tough and then I found this set;
http://img.photobucket.com/albums/v239/joelwideqvist/chopper/A9D9E864-1ED4-40BE-85AC-9C4714FBA22B.jpg
Anyone tried them? Do they stick properly? Don't want to lose any.
Other option is of course to go all in on brass rivets. I can just find sets with a pretty long pin, like 5 mm or so. Anyone know of round brass rivet set with shorter pin, like 2 mm?
Soon I'm off to do some building instead of disturbing you with questions :-)
/Joel
wadny
01-04-2015, 10:27 AM
Those are just photo-etched parts - they don't have any adhesive on them. You will have to glue each one in place, using a small drop of superglue, clear paint, white glue, or your favorite photo-etch glue.
sam01contact
01-04-2015, 10:32 AM
I use those rivets all the time and they are NOT stickers, you must use a little glue to keep them in place.
I don't know any rounded brass or gold coloured rivets. For your project you could use something like this
http://www.hlj.com/product/t2m-1076/Aut
the pins are 2 mm long. the rivets are hexagonal, but they have a rounded flange.
Let us see the finished rims!
joelwideqvist
01-04-2015, 10:49 AM
Ah, ok, I was under the impression that they had a sticky back. My bad.
There are a lot of brass rivets around, but all I find have long pins. They can be cut of course but that also means a lot of extra work, drilling 150 holes will sort of be enough ;-)
The rim is going to look like this;
http://img.photobucket.com/albums/v239/joelwideqvist/chopper/C3352244-DAB8-4AFF-8463-0E2CAC2A504C.jpg
joelwideqvist
01-04-2015, 10:59 AM
When thinking it over, PE bolt heads would be the way to go. Looking at this Scale Motorsport sheet I see that they aremade out of nickel, first look made me think they where golden in color but they are silver. Looking around I can find some Lion Roar set that is also silver - anyone know of a set of brass ones? The sheets with rubber backing is perfect, cleaning up 150 tiny parts from fret edges will kill me.
Exotics_Builder
01-05-2015, 10:28 AM
Can I assume you are looking at 1/24 scale? You didn't specifically state that. Regardless, there are several rivet options that can be used across multiple scales. Check this link out for options:
http://www.hlj.com/scripts/hljlist?searchpage=aut&qid=FFXWLNSNKZ9R8W&Dis=2&q=1&GenreCode=aut&Word=rivets&set=1&DisplayMode=grid&Sort=std&Scale2=0
Also, there are 1/35 scale resin rivets from Meng and Callibre 35 that can be applied to 1/25 scale and perhaps 1/20 depending on size.
joelwideqvist
01-05-2015, 11:07 AM
The bike is 1/12, bolts are in a way cross scale but I figure them to be aprox 1 mm wide.
Exotics_Builder
01-05-2015, 11:59 AM
Top Studio and T2M have a lot of options for 1/12 bikes
joelwideqvist
01-05-2015, 12:40 PM
I know but I'd prefer not to drill 140 holes and rather just glue some flat pe heads in place. I guess painting the scale motorsports ones above gold is the best solution.
Exotics_Builder
01-05-2015, 06:19 PM
Have you looked at Archer Transfers resin pieces?
http://www.archertransfers.com/
joelwideqvist
01-06-2015, 08:39 AM
Yes, I've seen them but don't really get it. Is it resin dot on some paper packing? Are they black as in the pictures?
Exotics_Builder
01-06-2015, 10:17 AM
More dark gray. I have some but have yet to use them.
ketje
01-10-2015, 08:10 AM
Look at this one.
http://www.micromark.com/ho-scale-decals-with-raised-3d-rivets-and-other-surface-details,9968.html
These are a kind of 3d decals. They have to be painted afterwards.
Ketje
joelwideqvist
01-11-2015, 06:14 AM
Look at this one.
Ketje
Yes, I spotted those but as I want golden bolts on black rims I must get some that doesn't have to be painted when mounted.
ketje
01-11-2015, 11:42 AM
/Joel
Hey Joel,
you can always spray a clearcoat over these rivets after putting them in place. This will protect them also.
