Page updated on 07-20-2018
1/24 scale Enkei RPF1s
Wolf95
12-30-2014, 06:28 PM
I can't seem to find any 1/24 scale "17 inch" Enkei RPF1 wheels. SUPER common wheel IRL but I can't seem to find a set made by Aoshima or anyone... :(
HELP!!
axier_kazala
12-31-2014, 05:36 AM
I have also for 3d print in shapeways but with fujimi spindle , but i can change it in a moment:
http://shpws.me/uCA6
Wolf95
01-08-2015, 10:27 AM
yay!! I'm interested. Is there any way you could scale them to 17" rims? Also, where would I find proper sized tires to fit with these? (if you were to do 17s)
Thanks
axier_kazala
01-08-2015, 11:02 AM
Thanks
yeah, i can scale and make another pack,but i do not know to find any 17" tyres.
What type of spindle do you need?
Wolf95
01-09-2015, 09:47 AM
Tamiya s2000 hubs.
axier_kazala
01-09-2015, 11:09 AM
Tamiya s2000 hubs.
Well , when i finish them i will post here
axier_kazala
01-09-2015, 01:43 PM
Well i finished the pack of the Enkei RPF! in 17" it got a diameter of 21 mm and 11mm wide.
https://images4.sw-cdn.net/model/picture/625x465_3017972_8228890_1420829972.jpg
Here the link:
http://shpws.me/BIma
Wolf95
01-18-2015, 09:03 PM
How wide of a rim IRL would this make it? Not diameter of the wheel, but width of the tire surface?
For example, mine IRL are 17" diameter, 9" wide, and +45 offset (doesn't really matter in this case)
Wolf95
01-18-2015, 09:09 PM
Also, are you sure these are scaled correctly?
It shows 1.709" W and H.
17 divided by 24 is 0.71.
In the same aspect, it shows .42" as the width, which would be a 10" wide wheel.
Sorry, I just want to make sure I know exactly what I'm ordering.
axier_kazala
01-19-2015, 03:32 AM
No , problem but that is the size of the complete pack in IN and each rim sizes are in cm are inches:
(in) 0.802w x 0.42d x 0.802h
(cm) 2.038w x 1.068d x 2.038h
but htey have a small lip on the front so the diameter of the rim will be of 2cm .
If you have any specific size in CM sent me and i will modify the size of the rim
Wolf95
01-19-2015, 09:52 AM
OHH!! ok. That makes sense.
and sorry, but I'm not very good at scratchbuilt conversions yet. Whatever diameter would set the wheels at about 8-9" wide would work. Mine are 9" wide on my car. I'm still trying to find tires to fit them.
Thanks
axier_kazala
01-19-2015, 10:10 AM
This ones i think that they are 10" wide(i also havetrouble with the conversions and i normally workonly with cm),i can make them 9" wide
Wolf95
01-19-2015, 05:37 PM
Perfect. If you do that I can put in my order.
axier_kazala
01-20-2015, 10:59 AM
Sizes adjusted and pack done, here you have the link for them:
Wolf95
02-17-2015, 11:49 AM
They came in and look great!!
Thanks for everything.
One question though, when I went to paint them, the texture is slightly more rough than I anticipated... How would you recommend lightly sanding them (being multilayered and really tiny spokes)?
Thanks
axier_kazala
02-17-2015, 12:32 PM
Thanks
I normally sand it with very fine sandpaper or an all sandpaper and doing it very relax because they are very tiny parts .
Im glad that they arrived well
Wolf95
02-18-2015, 07:44 PM
Hmm.. I'll try that. Thanks.
Wolf95
03-18-2015, 09:25 AM
Shoot... I was test fitting tires and pressed too hard and snapped one of the wheels. Is there any way to order another pair or individually?
Hemi Killer
03-18-2015, 04:33 PM
edit: wrong information
If he will print out 5 wheels to make it worth his time, I will take a set and he can send you the 5th.
axier_kazala
03-18-2015, 05:57 PM
So if ca make a pack of 5 rims or only one?
I got no problem
Hemi Killer
03-19-2015, 12:00 AM
I got no problem
He broke 1 wheel and only needs one, but may not be worth your time to only make one. If you make 5, I will take a set of 4, and you send one to him
So 1 wheel to Wolf95 and 4 wheels to me. Probably better to make more if taking the time to set up the machine, no?
Lownslow
03-19-2015, 03:13 AM
Thanks
I use a sandblaster to clean mine then use filler primer.
axier_kazala
03-19-2015, 04:16 AM
I will upload the pack this afternoon
Wolf95
03-19-2015, 02:32 PM
Just make it 6. I could use an extra extra spare, just in case. That works for me and makes more sense. If I had to, I would just pick up a whole set. But if we can make this work, that would be awesome.
axier_kazala
03-19-2015, 03:15 PM
Well, pack is done. Here is the link:
http://shpws.me/GIR6
Wolf95
03-20-2015, 09:20 AM
So would hemi killer then buy the kit then send me just the two? Or how would we split that up. Looks like it's about 5 dollars per wheel, plus shipping.
Wolf95
03-20-2015, 09:23 AM
Also, is there some place we can leave you or that site a good review for being awesome?!? Lol
axier_kazala
03-20-2015, 12:04 PM
Yes, he would buy the pack and then you should speak with him about the price an that.
No, i dont have any site, because i dont know how to do it and also i dont know how it works jajajaja.:grinyes:
Hemi Killer
03-20-2015, 09:52 PM
I'll send you a PM
Thank you Axier
Hemi Killer
03-29-2015, 09:53 PM
Axier, I purchased the pack, thank you very much.
Hemi Killer
04-04-2015, 05:41 PM
Here are the wheels I got. Very nice.
http://i.imgur.com/4C8aL2H.jpg
Wolf95
08-30-2015, 09:34 AM
Would love to see yours after paint. I sprayed mine again and they're still pretty rough :/
airforceone
08-30-2015, 11:13 AM
The texture is a result of the printing process. It is pretty much unavoidable, but the prep should be minimal. What kind of primer did you use?
Wolf95
09-01-2015, 08:13 AM
I didnt use primer on these in hopes it wouldn't fill in the lug holes and look puddled. I sprayed them a while back with no prep done (stupid mistake), but went back over them all with wet 1500 and came up with something BETTER... but still not the finish I'm looking for..
Wolf95
09-01-2015, 04:11 PM
Here are the rpfs after 2 attempts to spray them. Compared to the Mugen MF10s the kit comes with that I sprayed with a similar silver.
Had to replace one after breaking out the whole face of an old one.. and a spoke snapped on this one while trying to wetsand. >_< Super brittle.
http://i382.photobucket.com/albums/oo262/wolf9599/model%20stuff/IMG_3625_zpsomqazysa.jpg (http://s382.photobucket.com/user/wolf9599/media/model%20stuff/IMG_3625_zpsomqazysa.jpg.html)
http://i382.photobucket.com/albums/oo262/wolf9599/model%20stuff/IMG_3624_zpsn4le9dfi.jpg (http://s382.photobucket.com/user/wolf9599/media/model%20stuff/IMG_3624_zpsn4le9dfi.jpg.html)
bhop73
09-01-2015, 09:58 PM
They look sweet! It seems like it'd be worth it to just use the 3d print as a master for some resin casts, to make it easier to work with and paint.
Hemi Killer
09-03-2015, 12:53 PM
what about using filler primer or something, then lightly sanding that smooth
NOMADGAMER
09-03-2015, 06:33 PM
+1, you need some self leveling primer.
Wolf95
09-03-2015, 09:23 PM
I agree with that. Like I was saying, I was trying to lay just light layers of silver to avoid puddling in the center and making the lug nuts disappear.
Hemi Killer
09-06-2015, 01:45 AM
I broke one of these wheels as well. They are VERY brittle.
axier_kazala
09-06-2015, 09:12 AM
Im sorry about that defect, im working on that to not happening again.I also have broken by now 4 sets, because im measuring the size to dont broke them.
Im changing the size to different model i have like the MB and this ones.
This picture is of the last set with the fatlace rim after priming them.
https://41.media.tumblr.com/38d117d410cf3277c9acb0e90d81dbce/tumblr_noeekaMlJG1sr8en1o1_1280.jpg
Lownslow
09-06-2015, 12:57 PM
Why like making my wheels with a 1mm spoke minimum
Wolf95
09-21-2015, 10:21 AM
I think just for handling purposes, these should be remade with slightly deeper spokes so it doesn't throw off the looks THAT much, but will hold up against sanding/handling.
axier_kazala
09-21-2015, 02:47 PM
I finished this new version of the RPF1 rim and now is 0.6mm depper than the previous version.I will finish the packs and i will upload it again.
https://40.media.tumblr.com/021faf67735736edca9a0ec7e674b780/tumblr_nv1lgdWrcC1sr8en1o1_1280.png
Hemi Killer
09-21-2015, 04:26 PM
Axier, thank you for addressing this, much appreciated
axier_kazala
09-21-2015, 04:39 PM
For the moment i only uploaded the Enkei RPF1 17" rims with tamiya spindle.
The aoshima spindle ones i will finish and upload them tomorrow.
Thank you all, for helping me telling the deffects to correct and improve them.
Wolf95
09-27-2015, 11:26 PM
What about the rough finish? Any way to smooth that out?
axier_kazala
09-28-2015, 04:04 AM
Well, i tried to smooth with fine sandpaper but you have to be very patient. I am going to try with the next packs that are arriving to smooth them with acetone but im not very sure if is gonna work because i only have seen used on ABS.
