How to remove '95 radio?iflatow 06-25-2003, 05:13 PM I'm looking to replace factory installed radio in '95 Passat and need directions on how to remove the old radio. Thanks! Deakins 06-25-2003, 05:35 PM You need some of these: http://pix.crutchfield.com/lifestyle/2000/h150DINTOOL.jpeg iflatow 06-26-2003, 10:54 AM Thanks for the reply! These "things" look quite interesting but I need a bit more information: 1. What are they? 2. How do I use them..? 3. Where can I get them? 4. Any further instructions? Thanks! I. Flatow Deakins 06-26-2003, 02:11 PM It's a pair of standar DIN radio removal tools, you can get them at the dealer or any local Autozone, car audio shop, etc. To remove the radio, insert the DIN tols into the two holes on each side of the radio to release it, then tilt them a bit sideways and pull the radio out. Once you have it out, disconnect the wires, and connect the new unit. iflatow 06-26-2003, 03:22 PM Thanks! I'm almost embarassed it looks so simple... iflatow 07-16-2003, 10:38 AM Thanks for the tip...radio removal was a snap. One problem: the VW radio antenna jack doesn't match the replacement radio jack, which is a standard "banana plug" style jack. Any hints on where to find an adapter or replacement? Thanks. SolTheHoelessPimp 07-17-2003, 03:28 PM any car audio shop should have an adapter. bruno_grewal 05-12-2004, 09:17 PM retarded lil specialty tools like that are usualy over priced. would it be posible to use something else to get the job done? :eek7: bruno_grewal 05-12-2004, 09:59 PM jus gave it a try, save your money! coat hangers work :icon16: a coat hanger, a paperclip and ductape, the only tools you'll need to fix anything :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
