91 Corolla is lurching and misfiring
Camelboy19
02-21-2014, 01:25 PM
my 91 corolla likes to lurch and misfire. also there seems to be a slight loss of power to the engine. clutch isn't slipping. whats going on? friend said it might be the distributor
Brian R.
02-21-2014, 02:41 PM
Sounds like an ignition problem.
Check your plugs, plug wires, distributor cap, rotor, coil.
Camelboy19
03-21-2014, 08:21 PM
My toyota is still sputtering. I replaced the oxygen sensor and the fuel filter. Both havent been touched in years. I don't know what's wrong. Took it to the shop and they can't figure it out either
Brian R.
03-22-2014, 10:34 PM
Did you test your ignition as I suggested?
Even if the coil tested good, as long as you can't locate the problem, I would replace the coil. It is the weak spot in the ignition.
