99 Monte Carlo Keyless remotemurphturph 06-21-2003, 10:52 AM Greetings I have a 99 Monte Carlo and need to Keyless remote programming procedure. Thanks in advance. P.S. Great Forum for the self help types. Shortbus 06-21-2003, 11:18 AM <strong>Transmitter Programming</strong> If the vehicle has more than one keyless entry transmitter, ensure that all of the keyless entry transmitters are programmed during the same programming sequence. Any keyless entry transmitters that are not programmed will not work correctly. Open the rear compartment lid. Pull aside the right side compartment trim in order to gain access. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End. http://files.automotiveforums.com/uploads/202433rcldr.jpg Use a jumper wire with alligator clips in order to ground the RKE programming connector. The door locks will lock and unlock. This action indicates that the RCDLR has entered the keyless entry transmitter programming mode. While the programming connector is still grounded, program each of the keyless entry transmitters, one at a time. Press and hold the LOCK and UNLOCK buttons simultaneously on the first keyless entry transmitter. Hold the buttons for 10 seconds. The door locks will lock and unlock. This action indicates that the keyless entry transmitter has been programmed. Repeat Step 4 for the remaining keyless entry transmitters. You may program as many as 4 keyless entry transmitters. Remove the jumper wire from the RKE programming connector terminal. Verify that the keyless entry transmitters operate correctly. Install the right side rear compartment trim. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End. Close the rear compartment lid. Hope this helps you out. murphturph 06-21-2003, 03:07 PM Thanks John for the fast reply, But... Pulled the trunk carpet up on both sides and didn't find the module. I did find a control module under the steering column with two plugs. My car is a LS model with the 3.1 engine. Must be another method... Thanks in advance. Murph Shortbus 06-21-2003, 03:11 PM Originally posted by murphturph Thanks John for the fast reply, But... Pulled the trunk carpet up on both sides and didn't find the module. I did find a control module under the steering column with two plugs. My car is a LS model with the 3.1 engine. Must be another method... Thanks in advance. Murph No, the module is not inside of the trunk. It is on the rear package shelf.. where the rear speakers are. murphturph 06-21-2003, 10:22 PM OK, I found the module and am now cornfused about how to "ground the RKE connector" per the initial instructions. Already blew the power locks fuse. Almost there, I can feel it. Thanks again. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
