2002 wire harness?TT03Z 06-07-2003, 08:52 PM Where is the trailer wire harness located at on the 2002 rodeo? rodeo02 06-27-2003, 10:08 PM I havn't checked on mine, but it used to be in/behind the jack storage compartment. G/luck Joel toddz13 08-09-2003, 12:59 PM I didn't find mind readily available there, did you have to tear it apart? The door hinge really gets in the way if I have to do that. I did find a female connection under the truck that stops pretty much right below the jack compartment, on the driver side. Is this wire to plug in a trailer hitch harness? Anybody? rheteric 05-19-2004, 11:16 AM Sorry for the late reply, but I thought I would lend my $.02: Where is the trailer wire harness located at on the 2002 rodeo? Not sure if there is one?!?!?! I'm looking to do a hitch and the T-connector is the only wiring option I've seen: http://www.hiddenhitch.com/Products/DisplayAccessory.asp?AccessoryID=16360 Anyone know of an alternative or better option??? toddz13 05-19-2004, 09:45 PM I hooked mine up to both sides of the tail lights, with a linking male/female t connection. The most important thing is that you go to a tailgate/hitch center and get the Rodeo specific wire harness. Uhaul and many other places sell a universal wire harness but it requires splicing so beware of rain, water, and whatever else that comes with that. unscrew the tail lights , you'll need a long screw driver, I think the screws were mostly at the bottom of the lights. pop out the black side molding near the inside of the hinge by the tail lights. pull out wires as much as possible It was kind of a two man job as I didn't tear the car apart more than that, but I squeezed my fingers in and got everything connected within a half hour. It works great and tows excellently. Godd luck TT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
