Page updated on 06-25-2018
2004 Suburban Rear Blower Inoperative
mslevens
03-28-2013, 02:06 PM
If rear blower fails to come on, check the two fuses, one under the hood, the other by the drivers side of dash board,you have to open the door.If they are good, go to the drivers side kick panel, by parking brake release handle. Pull the panel gently towards you to disengage the clip. Look at the connector behind the panel for burned discoloration. If you have a burnt pin you will have to jumper the connectors orange wire by cutting, stripping and soldering a heavy gage insulated jumper. Dont troubleshoot the motor as I did and I almost replaced the resistor network.
