possible new engine time...
luvmy02impala
03-24-2013, 01:47 PM
I have a 06 Impala with a 3.5L V6. I was just told that the head gasket on the firewall side is leaking and time to replace. The engine has 136k miles on it. The job was approx $2800.
The body and interior are in excellent condition. I figured for a few hundred/maybe $1k I could get a new engine. I figured that instead of just doing the top end, the whole thing should be done.
Should I replace the tranny as well? It seems that if it were to go it would be expensive to replace because the new engine would have to come out any way. Costs are not an issues at the moment, and I am considering the engine/tranny combo for replacement.
Anyone ever use Jasper engines for engine replacement? Since it is has a 3.5L would it be an easy upgrade to go to a 3.9L? I love the car and the fact I do not have a car payment, so the engine swap seems reasonable.
Thanks in advance for all answers...
maxwedge
03-24-2013, 05:55 PM
2800 for a head gasket job!!, the book time is about 14 hours tops, how did they arrive at that number. I would get a second estimate.
gmtech1
03-25-2013, 11:49 AM
Agree with Max...Alldata time is just under 10hrs to do both headgaskets. If their rate is 100.00hrs that 1000.00 + tax and parts. Get another estimate.
luvmy02impala
03-25-2013, 08:46 PM
Thanks, the car is set to go in Saturday to a local shop. I will post what was found as I tell him to look for the source of the leak.
As for replacement engines, what are your thoughts on Jasper engines?
Thanks.
Thanks.
Tech II
03-26-2013, 09:26 PM
Just make sure it's the head gasket and not the gasket on the head for the coolant crossover pipe.....
Yeah, that quoted price does seem high....online estimate of $1610-$2207........
luvmy02impala
03-28-2013, 12:34 PM
Is there a difference in labor for that crossover part?
gmtech1
03-28-2013, 01:05 PM
The crossover would be a MUCH cheaper repair...
luvmy02impala
03-30-2013, 06:17 PM
Hello,
My shop showed me the trouble. It is the head gasket, the block is wet from under the manifold on the one side and wet spots on the front side. His quote was along with the dealer at $2800. I made no mention of the previous quote or trouble from the dealer. He would replace the head gaskets and have the heads rebuilt, flush cooling system, replace the water pump, clean throttle body, clean fuel injectors. It is booked at 18 hours.
On the other hand a Jasper engine would be $3500 plus $1100 installed. So it comes down to $3000 vs $5500. Jasper has a 3yr/100k warranty on it, any trouble the engine is replaced.
Have to think about this. The car body is in excellent shape and a very clean interior. My mechanic went over the car and found no issues other than need new struts to worry about.
Thanks to all who posted in this thread.
la1
03-31-2013, 12:15 AM
I would get the head gasket replaced , that's just me though. I don't know about the 06' but the 00 - 05' could pull the rocker arm stud out now and then, so have them look over the valve train. What gasket manufacturer are they going to use? How long will they guarantee the work ?
luvmy02impala
04-07-2013, 07:12 PM
Warranty is 12k miles/12 months. Do not know the gasket manufacturer...
Still thinking about replacing the entire engine...
la1
06-06-2013, 03:13 PM
Fast forward 3 months.....SO what did you do and how did it turn out.
luvmy02impala
08-27-2013, 12:30 PM
I am still driving it, it is not leaking that bad at this time. So I am trying to hold off until I have to replace it. $ is tight, especially for that $3k on an older car.
If I get it fixed I will post here.
Also thinking about getting new Impala (2014).
SierraK1500
08-27-2013, 09:25 PM
The 2014's are all new design. Very expensive and I would wait a year for all the bugs to be ironed out. I just bought a 2012 with 19K on it at a great price. Consider a 12 or 13
luvmy02impala
08-07-2014, 08:49 PM
Update. The car was traded so I will no longer update this thread. Happy Motoring!
la1
08-08-2014, 05:27 AM
The 2014's are all new design. I myself don't like the way the 2014 Impala's look, maybe after awhile. It may not just be me. I went to the dealership the other day and I forgot what they call them its not retro, something like that. They had 3 2014 Impala's that looked just like the 2012 model year.
as far as the head gasket they have that liquid head gasket repair, they have that guy on you tube scotty kilmer who makes all those auto repair videos, one he uses the liquid head gasket reair and he said it worked
