Elantra Oil Control Valve Removal
aldavidson
02-01-2013, 11:00 PM
My Elantra has a Check Engine Light with P0011 code indicating timing is over-advanced. It runs perfectly fine. I'll need to do something about this a sit will cause me to fail the new Ontario Driveclean test. It seems to point to the Oil Control Valve not working or it's filter is clogged. I cannot see how the OCV is removed. There's a single bolt to the right which I can unscrew ok but then what? Is the OCV then just a push fit or is there soemthing else to undo, as it still seems to be quite tight.
Any advice would be appreciated.
