Please help.. PE parts won't CA/solder together.
Averion
01-21-2013, 12:29 PM
Hi all, I'm using the wing from hobbydesign, the construction of the wing looks really neat, if it could stick together.
Well my problem is this, as you could see from the diagram, you have to insert one of those rivets(aluminium i think) through 3 PE parts for the wing mounts.
However, after trying to CA them together and letting them cure for 1 night, one slight movement, would just crack the CA, and all the parts would come unjoined.
Thought solder would help, but realised after trying, solder does not stay on to the PE/rivet probably due to the material.
Really feel like all hope is loss and this is a terrible design to build a wing, some plastic mounts would have been so much easier!
http://i91.photobucket.com/albums/k286/leafwerks/one%20twentyfour/Tamiya%20S2000/IMG_3327_zps53607a67.jpg
RonCla
01-21-2013, 02:48 PM
I would use a 2 part epoxy adhesive.
stevenoble
01-21-2013, 02:54 PM
2 part epoxy glue is your best friend...
Helico
01-22-2013, 01:43 AM
Lightly sand the surface before applying CA glue or epoxy.
CFarias
01-22-2013, 02:02 PM
All of the above suggestions are a great way to solve your problem. Also, be sure that the parts are wiped down with some window cleaner to get rid of any oils that could prevent the glue from sticking to the parts.
Averion
01-22-2013, 11:57 PM
Thank u so much for all your help, juz gotten some epoxy 2 part glue, wld post pictures here after I tried it.
Thanks again!
Averion
01-23-2013, 04:00 AM
It worked! =)
http://i91.photobucket.com/albums/k286/leafwerks/one%20twentyfour/Tamiya%20S2000/IMG_3722_zps7ea16887.jpg
RonCla
01-23-2013, 05:12 AM
Excellent :bananasmi
Vladamor
01-30-2013, 02:29 AM
Congrats!!!! What thing did you used finally???
Averion
01-30-2013, 07:27 AM
2 part clear epoxy glue. works like magic! haha!. but its quite messy to work with, the mass of the glue is quite thick.
