Internal wastegate boost adjustmentmrchris1979 06-06-2003, 05:23 AM I've got an extra turbo that uses an internal wastegates to control boost. T-25 from an '98 Eclipse. I plan to build my own using T-25 in a D16a CRX motor. How can I adjust the internal wastegate to increase/decrease boost ? Is it possible to remove the internal wastegate and use an external one instead ? Cronic 06-06-2003, 09:46 AM To lower the boost, you must either have a new spring put in the wastegate, or a new wastegate installed. I believe t25's use a diaphram, and may not be adjustable. Altho the 7psi it pushes out stock + intercooler pressure drop should be good, you prolly don't want to go any lower then that. To raise the boost, either get a boost controller, or bleed the boost away from the actuator, I use vacuum tee's sometimes. :D vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
