Problem toyota corolla 2006 after change battery
legend2563
12-01-2012, 04:52 PM
toyota corolla 2006 107,000 millage engine 1zz
HELLO ALL,
I NEED TO HELP ON THIS MATTER I AM HAVING PROBLEMS WITH MY COROLLA LE 2006 IT HAS WHEN THE A/C IS OFF AND CAR IS ON ITS TEMPERATURE NORMALLY THE IDLES ARE VERY LOW 615 AND EVEN 600 AND START VIBRATING. WHEN I TURN THE A/C ON THEY GO UP A LITTLE BIT.
WHEN CAR IS COLD ITS PERFECT UNTIL ITS ON ITS NORMAL TEMPERATURE THIS CAR IS REALLY DRIVING ME CRAZY. I HAVE CLEANED THE THROTTLE BODY EVEN TOOK IT OUT AND CLEANED IT COMPLETELY AND STILL SAME ISSUE, THE ONLY THING I HAVE NOT DONE IS CHANGE THE INTAKE MANIFOLD GASKET SINCE I SAW A RECALL BECAUSE IT HAS NOT GIVEN ME THE P0171 CODE.
I SCANNED THE VEHICULE AND IT HAS STATED IN THE RECALL IS THE SHORT FT IS - THAT I NEEDED TO CHANGE THE INTAKE MANIFOLD GASKET BUT LIKE I SAID BEFORE I DONE HAVE THE P0171 CODE.
I USE TECHSTREAM TO SCAN THE VEHICULE PLEASE SE BELOW ALL THE INFO I GOT AND PLEASE HELP I AM EVEN THINKING OF SELLING THIS CAR I AM SO DISSAPOINTED IN TOYOTA FOR ALL THIS ISSUES.
and noticed another thing is that when the rpm to slow down as it reacts automatically upload your rpm and normal as the ecu reacts and says that should not be there is there (lol) as it reacts late ... just when I have the brake depressed to vece fall and rise again normally..
I ALSO FEEL THE CAR HEAVY LIKE SLOPPY AFTER ITS NOT COLD.
mi live data with when the car start cold until it takes its normal temperature
mi value
http://postimage.org/gallery/7dlow96/843965d9/
HELLO ALL,
mi value
veedubmechanic
12-20-2012, 09:48 PM
Clean your throttle body with throttle plate cleaner (oxygen sensor safe kind) very good and report back
