Oxygen Sensor Question
MyTaurus8AChevy
11-26-2012, 12:43 PM
2004 Taurus. I have an important question about the oxygen sensors.
Do they get their ground signal by being mounted to the exhaust, or do they get their ground signal via the wiring harness?
In other words, if the oxygen sensor was plugged in but NOT mounted, would it still work correctly? :confused:
65comet
11-27-2012, 08:03 AM
Are you trying to have the oxygen sensor outside the exhaust pipe in hopes that it will read good outside air and pass an emissions test? I'm pretty sure that won't work. There is a thread here somewhere that explains how the sensors work. The exhaust has various flanges and rubber isolated mounts, not good conductors for a ground. I'm pretty sure the sensor has two wires, so I'm going to say one is for ground. If I wasn't in the office and have a meeting in a few minutes I'd verify this info and find that thread for you.
MyTaurus8AChevy
11-27-2012, 11:54 AM
No.
Some background; My car does not get a catalyst test reading when I take it for the emissions test. They keep saying that their computer 'can't access' that part of my computer, and to keep driving the car so it "resets". Problem is I've been driving the car for almost a year now and it still never resets.
The car was running 100% for as long as I've owned it (around 5 years now). It was the most dependable car I've ever had, bar none. Then I bought a new Milan and didn't trade the car in because they wouldn't give me a fair price for it. I was planning on selling it myself but then my father died and so I parked my car and decided to sell it after matters settled down. Problem was my mother was also dying of Alzheimer's and I was her only caretaker. She passed away around 6 months ago. Long story short the car sat for around two years and then it wouldn't start, and even the few times it would start it ran terribly bad. After looking into it I decided that the only thing that made sense was that it had to do with bad gas gumming everything up. So I flushed the gas tank, installed a new fuel filter, plugs and oxygen sensors. It now runs great again BUT I cannot get it reset the catalyst test.
I can no longer drive it on the street because they only allow two 30 day tags before I can get plates BUT without it passing the emissions test they wouldn't allow me to buy plates. That's become a whole other ball of wax. Right now I just need to figure out how to get the car to pass the test so I can proceed onto the next phase (getting plates).
I've been doing everything that I can imagine to try to figure out what the problem is with the car not being able to pass that catalyst test. Then I remembered last week that when I installed the bottom oxygen sensor that it might not be properly grounded, and if that's the case then "maybe" that's why the cars computer won't reset the catalyst part of the test.
You see the old bottom oxygen sensor was fused solid to the exhaust pipe. I had many people look at it but no one could get it to budge. Then one mechanic told me that I could buy a new threaded fitting and simply drill a new hole in my exhaust and install the new oxygen sensor there, which made sense. So I ordered the fitting and mounted the new oxygen sensor around an inch from the one that was stuck. I was told that I would need to weld the fitting on the exhaust pipe, but because of dealing with paying for both funerals I am in deep debt and have no money for welding, so I drilled the hole slightly larger than the new fitting and hammered it into place. It was a tight fit, but I knew that when the exhaust heated up that it would expand so I also put high temp adhesive all around the fitting to keep it in place.
Here's the reason for the question; if the new fitting was welded into place then I know it would be grounded through the fitting and oxygen sensor threads, but the way it's mounted now my theory is that maybe it's not being properly grounded, and that's why the cars computer doesn't see it. If the oxygen sensor gets its ground through the wire(s) then I am once again stumped as to why the car can't see it, but the "ground through the exhaust" issue sounded logical, so I was looking into if it was a possible solution. Hope that all makes sense.
If you get a chance then that would be great. I'm grasping at straws trying to figure this out.
No.
shorod
11-27-2012, 12:15 PM
Years ago there were single wire O2 sensors that relied on the exhaust system as the ground reference, but with OBD-2 the heated oxygen sensor became common and has a dedicated return path for the sensor element as well as the heating element. On your car the sensor return path will be the Gray/Red wire for each of the 4 sensors.
-Rod
-Rod
shorod
11-27-2012, 12:18 PM
Do you happen to have a scan tool that will allow you to monitor the 4 O2 sensor readings in real time with the engine running ("Datastream" or "Live Data" modes)? If not, you should be able to pick one up for less than $200 (much less if you have an Android phone with the free Torque app and OBD-2 dongle. You can get Bluetooth dongles for around $20 that will in all likelihood work just fine for what you're trying to do.
-Rod
-Rod
MyTaurus8AChevy
11-27-2012, 12:20 PM
I only saw (and replaced) two sensors. Might this be why the cars computer can't reset?
shorod
11-27-2012, 12:22 PM
Possibly. There should be one sensor in front of each catalytic converter and one sensor after each converter for a total of 4. It's also possible that you will have 3 sensors if your car only has one converter after the two downpipes are y-ed together. I pulled up the diagrams for a 2004 Taurus with the FFV engine since I didn't see any detail on which engine your car has. Maybe the non FFV vehicle only has a single converter? But at a minimum you're missing one of the O2 sensors.
Edit: I just checked the diagram for the gasoline engine, non-FFV 2004 Taurus and it also lists 4 O2 sensors.
-Rod
-Rod
MyTaurus8AChevy
11-27-2012, 12:25 PM
Thanks Rod! Is this the correct Torque app that you were talking about?
https://play.google.com/store/apps/details?id=org.prowl.torque&feature=more_from_developer#?t=W251bGwsMSwxLDEwMiw ib3JnLnByb3dsLnRvcnF1ZSJd
shorod
11-27-2012, 12:28 PM
Yeah, looks like it. Since I have the Torque Pro app that link automatically takes me to Torque Pro (which runs around $5). Torque Lite is free. I have a couple of different bluetooth dongles, both were around $20, and one works with almost no errors, but even the one that has errors still should work fine for your purposes. The one that works less well I picked up off of eBay, the "better" one I picked up from an online store, but I don't recall which. This evening I could dig through my receipts and probably find out where I got it if you're interested.
-Rod
-Rod
MyTaurus8AChevy
11-27-2012, 12:35 PM
That would be GREAT! I do have a bluetooth dongle (http://www.ot-2.com) but I don't know if it will work with this app. I will also try to contact the app developer and see what they recommend. Any help trying to figure this car out is greatly appreciated!
MyTaurus8AChevy
11-27-2012, 12:42 PM
Here is a list of dongles recommended by the developer. Could you look and see if the one you're using is listed? Since funds are so limited I'll only be able to try one.
http://torque-bhp.com/wiki/Bluetooth_Adapters
shorod
11-27-2012, 01:03 PM
The Vgate Scan Bluetooth adapter in the middle of the "China/via eBay/Amazon" list is the same case as the one I have that suffers from errors. The one below it is similar to the one I have that works quite reliably, but mine has a black housing.
-Rod
-Rod
MyTaurus8AChevy
11-27-2012, 01:22 PM
To clarify, this is the one that works OK?
http://www.amazon.com/ELM327-MINI-Bluetooth-software-CAN-BUS-Scanner/dp/B0079G1JU8
shorod
11-27-2012, 01:54 PM
Correct, assuming there are not a bunch of different guts in the same housing. That unit looks identical to the one I have that suffers from errors, but is still quite useable.
-Rod
-Rod
MyTaurus8AChevy
11-27-2012, 05:23 PM
I was looking at the Torque app and was wondering what display setting(s) I need to look at my car, O2 volts?
shorod
11-27-2012, 10:44 PM
Yep, O2 volts would be good ones to monitor. The B1S1 and B2S1 voltages should switch rather rapidly and the B1S2 and B2S2 voltages should change very little, and ideally read 0.45 V (or slightly higher).
It may be interesting to check the short and long term fuel trim values as well.
-Rod
-Rod
MyTaurus8AChevy
12-19-2012, 11:44 AM
Hi Rod, I'm about to order this and I have done a lot of research so that I order the right one. There appears to be two different manufactures for these ELM327 units even though they look very similar. Could you please look at yours and tell me which one you have?
You can tell by looking at the connector tab in the middle. One is completely molded into one piece, like the one below (we'll call this elm 1);
http://angelars.com/pics/elm327/elm327-1.jpg
The other has a separate tab like the one below (we'll call this elm 2);
http://angelars.com/pics/elm327/elm327-2.jpg
Which style do you have, elm 1 or elm 2?
Also some have serial numbers on them and some do not. Does yours have a serial number on it anywhere?
I also bought the paid version of Torque. I don't know if I need the extra features but I wanted to support the developer, as this seems to be a nice app.
THANKS Rod :)
THANKS Rod :)
MyTaurus8AChevy
12-19-2012, 01:15 PM
Also, before I forget, you had mentioned that this car has 3 oxygen sensors but I can only find two. The good news is that I have access to the 2003 Ford service DVD. This is the same workshop DVD that all official Ford dealers use. Since you use these DVD's all the time I thought I'd ask, where do I find the oxygen sensors at? I looked in the emissions section but it generally just has vacuum routing in there. I also tried looking in the Workshop Manuals section but couldn't locate them in there either. Below is a screenshot of the main menu. Thanks.
http://angelars.com/pics/elm327/forddvd.jpg
shorod
12-20-2012, 06:59 AM
I'm quite sure my module has the molded recess like ELM1. I'll try to remember to take a look at the device this morning after I dig myself out of the snow.
As for the oxygen sensors, the information you'll find in the Workshop Manual portion will be quite generic as removing any of the oxygen sensors will be pretty similar. To get the specifics, I prefer to go to the wiring diagrams from the main menu and select the Engine Controls diagram for your engine and get the details there. In the upper right will be options to view the location, connector face and pinout, etc. You'll want to re-read post #7, including the edit at the bottom. I expect your car has 4 O2 sensors. In Post #1 you mention your car is a 2004. In the views above you have selected a 2003. That could make a difference (although I doubt it does) as to if you're looking for 3 or 4 O2 sensors. It will definitely be more than 2 though.
-Rod
-Rod
