factory 94 integra radio coderadio code
ivancito7
06-05-2003, 04:47 PM
i got my whole system stolen again so im installign the factory radio back i. its asking for code so how do i input it adn what is the actual code im suppose to press i have no idea. i hope someone can help.
TheNotoriousMogg
06-05-2003, 11:40 PM
try search engine
killah_xft
06-06-2003, 01:47 AM
the code should be in your owners manual.. for the car.., or if you contact your dealer (where you bought it) you should be able to call them up and get the code/s. sometimes there is a separate package for the stereo system in the glovebox..
AirAllen01
06-06-2003, 02:47 PM
Normally, they give you a card with the code on it. If not, you'll have to call the manufacturer (number should be on the radio) and give them the serial number. With that they can search your radio and give you the code. While you're their, you can ask them how to put the code in.
GScivic7
06-06-2003, 02:49 PM
i think they charge you for all this though, like 50 bucks or something
HookdUpTeg99
06-11-2003, 01:51 PM
I had to reinstall my factory radio last year...There is a code on the radio that they ask for so make sure it is NOT installed before u call them unless u write down the number first (forgot which number it was exactly so write all of them down just in case). To install it, all you have to do is connect the antenna/power cable to the back, slide it back in, and connect the screws in the back to the original steel crossmember.
