2000 Grand Am SE Tranny?
HeyBlondie
09-29-2012, 03:52 PM
So hi, I have a 2000, automatic Grand Am SE with 161,000KM in her and everything seemed to be working fine but as I was driving it today my speedometer just stopped working and when I try to get her up to second gear she kind of jerks forward, if that makes sense? Also, today when I was driving she couldn't gear up at all, she just went from first to second to third to fourth gear without picking up any speed.
I'm not a car savvy person at all but I'm pretty sure it has something to do with the transmission?
Any help would be greatly appreciated! :shakehead
thephantom1492
09-29-2012, 11:15 PM
Is there any light on on the instrument cluster? like ABS or check engine soon? You could have a faulty ABS sensor, many cars use those sensors for the vehicle speed, which the ECU use to make it's gear decision... I do not know however if this is the case for your car.
Tech II
09-30-2012, 12:32 PM
I'm thinking VSS.....
xeroinfinity
10-03-2012, 06:31 PM
it will shift normally even with a bad wheel speed sensor(s).
Sometimes it will also drive and shift with a bad VSS, just depends on how much the sensor is failing.
I would start by having the trans fluid level checked.
If that's good, get it scanned with a scan tool that can read trans codes. Other wise you are just guessing.
Also you might check your fuses for anything to do with the trans. :thumbsup:
