03 with at ticking sound
dagan06
06-12-2012, 12:43 PM
I have a 2003 with a 2.2DOHC and it has recently developed a ticking noise almost like a lifter tapping. It sounds like it is coming from the timing cover area. If the timing chain is going out would it make a ticking noise?
danielsatur
06-12-2012, 03:41 PM
Does this engine have an OHC?
If yes, it could be a cam follower, or cam tensioner.
see www.automotiveforums.com/vbulletin/showthread.php?t=954555
dagan06
06-12-2012, 09:25 PM
yes it is the 2.2 DOHC
danielsatur
06-12-2012, 09:35 PM
Is this a interference type engine?
If the cam chain was to derail, it could bend valves.
dagan06
06-13-2012, 07:03 AM
it is a non-interference engine. The noise is is on the passanger side and if I use a stethoscope i can tell it is about half way down on the engine
Tech II
06-13-2012, 07:06 AM
Ecotec engine?
Not sure if the TSB applied to '02 or '03 engine.....basically replace the cam sprockets, crank sprocket, chain tensioner, chain, and the oil nozzle(larger size to lubricate the moving parts)......
dagan06
06-13-2012, 07:18 AM
yes it is the ecotec. I noticed it has a small oil leak from behind the harmonic balance
Camaroguy97
06-14-2012, 09:51 PM
Did you check the oil first? It could also be your lifter sticking.
danielsatur
06-15-2012, 06:30 AM
If DOHC, it doesn't have hydraulic lifters.
Suspect a bad cam chain tensioner.
dagan06
06-15-2012, 08:24 AM
I check the oil on a regular basis as it has been using oil since I got the car, I just recently discovered where the leak was coming from. I am almost 100% it is the timing chain tensioner I found a video on youtube and it sounded just like mine.
