2001 dodge dakota 4 cyl. overheating
Murvul
06-06-2012, 07:16 PM
Started with a leak on the upper filler hose. Replaced the upper filler hose, the thermostat and it is still blowing off steam after a few minutes. The thermostat is allowing the hotwater to the radiator. Flushed the heater and the radiator. No other leaks. Tried the new cap and the old one and steam/water still blows off after a few minutes letting it run. The fan does turn on.
Dakaty
06-16-2012, 01:20 PM
I would take the thermostat out and see if that stops the overheating.
danielsatur
06-16-2012, 06:35 PM
Do you get HEAT when you turn the HVAC on Heat high max?
This will tell you, if coolant is flowing through the engine + heater core.
If not, use a garden hose with a little water pressure to force air out of coolant system.
DakotaSport98
06-27-2014, 11:27 AM
Two questions I would ask.
#1 does your truck have an electric fan?.does it kick in ?
#2 have you checked to see if you have a blown head gasket?
Im thinking you might have a blown head Gasket that releases heat into the coolant system under heat pressure.
This is only a suggestion. I hope I am wrong.
