Clock problem driving me crazy
vybechyld
05-06-2012, 10:08 PM
95 K2500 stock radio clock will not shut off with key out of ign. I can turn the key to acc and the clock will get brighter so I dont think its stuck in acc. I tried jiggling the ign switch like heck but the clock does'nt shut off. Funny thing, if I turn the key to the start position and slooowly turn it back the clock will shut off for about 2 seconds and then blink between 1 to 4 times I think randomly I don't know. Also if the key is out and I step on the brakes or turn the parking lights on the clock shuts off. The problem came with the truck and I recently had to replace the turn signal/cruise switch(broken hazard button) which I hoped would fix the clock too but sadly no.
Everything else works great except my right high beam (normal headlights work)
j cAT
05-07-2012, 08:58 AM
the ignition switch or the lock cylinder linkage may need adjusting or replacing. with this old vehicle I would replace the ignition switch as it is most likely very worn. not uncommon at this age for the switch to be doing this and other power issues .
